@Lyubomir Krastanov I need the original instrument cluster files for the same car model. The current files do not support some data displays and warning lights. Please provide the original files so that all functions work properly.
  • Replies 834
  • Views 68.3k
Hello everyone,
I'm looking for the latest calibration files for Navi 950 radio (A11 module):
VIN - W0LPF8E61G8025881
Base Model Number (CC) - 84026628
End Model Number (CB) - 84026628
P.S. if someone can share an USB update file for this unit, that would be nice too 😁
I think I can download files via USB, but I don't have any USB drives at home. If I can get a USB, I can try downloading files, brother.
4 hours ago, pupu14 said:
Hello everyone,
A11_Radio_Package_0fcd117d.zip
Hi everyone,
I have been investigating ACC (KSG) activation on a 2023 Chevrolet Equinox Brazilian market and I have made significant progress.
I want to share what I found and ask for help with the final step.
What I confirmed so far:
Brazilian Equinox has identical hardware to US spec with ACC — same front camera B174W, same part number 86796160
Camera already detects vehicles, detects pedestrians and performs emergency braking (AEB)
ACC menu is already present in the cluster and can be activated
I found the official GM wiring diagram confirming ACC (UEU-KSG) uses exactly the same modules and wiring as without ACC — it is 100% software
Block is confirmed in BCM — holding cruise button 3 seconds does nothing, cluster never switches to ACC mode
Donor vehicle confirmed:
VIN: 3GNAXMEG4PL149819
2023 Equinox RS FWD — confirmed KSG in RPO codes via decoderpo.com
What I need:
Can anyone identify which parameters need to be changed to enable KSG? Or does anyone have the BCM/ECM/EBCM XML from the donor VIN for comparison?
Hello everyone! Can anyone help me with the calibrations for the K71 automatic transmission in a 2013 Chevrolet Malibu VIN KL1GA69U9DB086131? Thanks
here my friend
KL1GA69U9DB086131_K71.zip
1 minute ago, hassan77h said:
Thanks, friend, it was quick))))
here my friend
W0LPF8ER8E8004341_K9.zip
@hassan77h No problem at all, brother. I really appreciate your time and help. I will be waiting for your reply whenever you are ready
VIN : W0VPD5DC8KG316637
P16
@tejiera 1G4ZP5SS4JU126768, PIN CODE = 1817
1G4ZP5SS4JU126768_P16.zip
@hassan77h Thank you so much my friend
Hi. Can anyone help with PIN for ECU for this two Vin numbers (original and donor ecu HSFI 2.1):
W0L0TGF4825236529
W0L0XCF6814065943
W0L0TGF4825236529
W0L0XCF6814065943
for Corsa c - Astra G, i can't get pin
here my friend
W0LGM5ES4E1148565_P16.zip
Hi, I'm replacing the BCM in my car with a facelifted one. I'm trying to enable the TPMS on my UJM, but I can't find the correct VIN. Can anyone help? Base VIN: KL1JF6859DK009106
Yeni Metin Belgesi.txt
Hello @all,
First of all I want to say thank you for your unbelieveable help for people who want to learn more about their electronic systems in automotive context.
My question and request:
I am looking for K20 ECM calibration+setup for: VIN: W0LPF6EN2C1001345 $CB: 55585024 $CC: 55573121
plus
K17 EBCM calibration+setup for: VIN: W0LPF6EN2C1001345 $CB: 13379599 $CC: 13352681
plus
A11 Radio calibration+setup for: VIN: W0LPF6EN2C1001345 $CB: 22805138 $CC: 22864076 +UPH
plus
K20 ECM calibration+setup for: VIN: W0LPF8EN8E8015224 $CB: 55590420 $CC: 55573121
plus
K17 EBCM calibration+setup for: VIN: W0LPF8EN8E8015224 $CB: 13412552 $CC: 13352681
plus
K43 EPS calibration+setup for: VIN: W0LPF8EN8E8015224 $CB: 13414033 $CC: 13394503
plus
K41 UPA calibration+setup for: VIN: W0LPF8EN8E8015224 $CB: 22810361 $CC: 22810365 UD5
plus
K109 FCA calibration+setup for: VIN: W0LPF8EN8E8015224 $CB: 23179697 $CC: 23179697
and for playing around:
K20 ECM calibration+setup for: VIN: W0LPF6EN3DG015706 $CB: 55585024 $CC: 55573121
K20 ECM calibration+setup for: VIN: W0LPD9EN0D2004487 $CB: 55585024 $CC: 55573121
K20 ECM calibration+setup for: VIN: W0LPF6EN0DG114631 $CB: 55585024 $CC: 55573121
K20 ECM calibration+setup for: VIN: W0LPD9EN0D2088875 $CB: 55585024 $CC: 55573121
That's a lot, I know, but old cars demand a bit more work to bring them up to date.
No need to have the cals in DPS format zip, I can do this self, I will sort the cals and create the SBAT files.
Thanks in advance for your help.
Toby
