  • Popular Post
Please everyone where requesting files to use following example.
Request files for (module)
VIN
if you have module available (in car/bench) please attach screen shot from DPS module info read.
Hope Admin to accept this post.
Most helpful reply by blocked,
1G6A15S62G0108570 K38.ZIP
  • Replies 834
  • Views 68.3k
@Lyubomir Krastanov
Hello 🙂
Could you download radio calibrations for these VINs:
W0VZM8EB8K1078176
2GNAXUEV1K6202326
Regards!
3 hours ago, ZZZ said:
@Lyubomir Krastanov
Hello 🙂
W0VZM8EB8K1078176
2GNAXUEV1K6202326
Regards!
For first VIN yes for free, for 2nd cannot get them free as my access is EU only.
On 4/17/2024 at 6:07 AM, ZZZ said:
@Lyubomir Krastanov
Hello 🙂
W0VZM8EB8K1078176
2GNAXUEV1K6202326
Regards!
This is for the W0VZM8EB8K1078176 VIN
Which Option do you want?
Edit:  Sorry it won't let me grab any of them.  I must not have the correct radio hooked up.  Sorry
Hello 🙂
If you could IOR option
Regards!
files for W0VZM8EB8K1078176
W0VZM8EB8K1078176 IOR A11.rar
for other VIN need to know OS number
Hello, I would like to acquire stock calibration and config files for K9 BCM module for this VIN:
W0LGT8E15G1006028
Also, I will try to retrofit factory alarm sensors. Is this as simple as replacing Cal_No.13 file for BCM to activate this feature?
W0LGT8E15G1006028
I can't get you the files, but you have to change 10 and 13. At least those were the ones I changed to activate the alarm on my K
Oh yeah, I have missed that No10 is also related to alarm.. 😄
What was your experience with retrofitting? It looks like factory roof wiring loom is missing a connector for alarm components (or is it present but well hidden further behind the lining?).
If so, have you recreated the OEM wiring (some wires must go back to trunk area..) or improvised?
W0LGT8E15G1006028
Will be later tonight as I’m at work right now. Please if you have car/module present, I need module info read via dps or Ident page from GDS2. Need exactly Base and End model numbers
Sure, I will provide screenshot from GDS2 later. I am at work at the moment too.. 🙂
Factory alarm sensors? That MY16 Insignia should have alarm from factory 🤔🤔🤔
Yes, unfortunately so. I guess it heavily depends on sales market - in the UK it may be mandatory, in other countries - not so much.
One thing I know for sure, is that's there is no connector for these sensors inside the front dome lights - so it wasn't somehow magically removed by a previous owner..
Here are the number you were asking for (hopefully):
End Model Part Number - 13506991
Boot Software Part Number - 13578437
currently my TIS access is offline, but have all files in my database. For Setup cannot help currently, but should be okay to use your
W0LGT8E15G1006028 K9.rar
Well, no bueno.. Can't download without donating again :D
Hello can anyone give me TCM And ECU for :
1GC1KWEY7JF218595
2G1FG1EW3F9149213
1GT49PEY6MF306833
@WSOpel some of files
WSOpel.rar
Hi, looking for calibration files for ECM
1GKER33D49J159949
1GKER33D49J159949
Did you read First comment?
Hello can anyone give me TCU and ECU files for
GMC Sierra 1GT424E82FF532115
Dear @Lyubomir Krastanov
can you get me calibration for IOT audio system?
VIN: W0VZX8GS1N1000900
Part number doesn't matter, because I would like to use only the language file and the radio calibration file to change the frequencies and the language in a IOT system.
If its success, I share with the community.
Regards, Janos
I think the part number still matters. Otherwise you can’t download calcfiles.
The language and the tuner calibration are the same for all part numbers. That's why doesn't matter the part number for me, it can be chosen the first one of the list.
Hello, I need the calibration for the two FINs for A11 without rear view camera
W0LBE8EC9H8057241
W0LBE8EB3G8089026
