On 4/25/2026 at 10:53 PM, Autobitas said:
Anyone can get cals for this Holden K33 HVAC (Base/end: 84137427) . W0VZM8ECXJ1155427
No one ? :)
  • Replies 834
  • Views 68.3k
Hello, dose anyone have these two HMI files?
07 - 39157959
08 - 84235591
Kind Regards
07 - 39157959
08 - 84235591
Kind Regards
have only 591, for other I will need source VIN
84235591.bin
Hi, need help with calibration files:
Chevrolet Bolt 1G1FW6S0XH4177788
We need in new updated firmware for iBooster.
System Supplier Id ($92) BOSCH03
Base Model Number ($CC) 42444468
End Model Number ($CB) 42525616
Software Module Identifier
DID Module ID DLS
C0 42348971 AB
C1 42348969 AG
C2 42565080 AA
OP system files:
42778597
0000D231
Обновление ПО/Калибровки ibooster SW/Cal. по причине щелкающего шума.
42348969
Отсутствует
Операционная система
Calibration files:
42778596
00000804
42565080
00008060
Изменение калибровки для кода неисправности U1833
42523631
Отсутствует
КАЛИБРОВКА СИСТЕМЫ IBOOSTER АВТОМОБИЛЯ
Has anyone this calibrations and their position numbers to make a flash file?
Thank you.
Help me get Cabliration TCM (Hardware: 24041958)
Daewoo LACETTI 1.8L (2H0) 2011
This is the VIN: KLAJA695DBK086227
Can anyone help with K9 BCM calibration files for W0LBF6EL9GG112907.Thanks
8 minutes ago, hassan77h said:
@hassan77h @hassan77h
Hi
Can you help me? I bought an old Corsa C for fishing or the forest, but I need a permit for the car. Can you help me? Is the Corsa from 2002?
W0L0XCF0824277366
18 minutes ago, Enterlan said:
Hi
W0L0XCF0824277366
Wrong thread for such questions..
But yes, it is 2002 MODEL year (car can be produced in 2001 too)
anyone can help me get the complete P16 Instrument cluster calibration/firmware for my car? the vin is: W0VZS6EB6J1169651
thank you in advance..
5 hours ago, JESUS RODRIGUEZ said:
quien puede ayudarme a conseguir la calibracion del radio de mi camioneta el vin es 3GNFK12347G281475
First of all, this is an English speaking community.
Second - need to know what radio you have..
hi can any one help me with ipc calibration 2GNAXUEV5K6131552.
THANKS
THANKS
post GCI log
3 hours ago, exc11 said:
post GCI log
the ipc dead it changed for one used, but it has another vin . i will se if with calibration i can change the vin.
Hi, need XML configuration for
UHS P16 Instrument Cluster
Insignia A
W0LGT8E10F1019199
Thanks!
THANKS
any one?
7 minutes ago, jorgecostacv said:
any one?
Provide DPS log of IPC.
Im sorry........
my radio is mp3 radio. thankyou. the file is for DPS
On 26/5/2026 at 0:51, pupu14 said:
En primer lugar, esta es una comunidad de habla inglesa
. En segundo lugar, necesito saber qué radio tienes.
hi here the log
thanks. i think i must change the vin and the pin to the used ipc work well.
ipc_GCI_Log.Txt ecu_GCI_Log.Txt bcm_GCI_Log.Txt
hi any one can help me with key for 2byte seed $8029 and the pin code for this vin 2GNAXUEV0K6147772
thanks
thanks
Seed for which module?
