1 hour ago, blocked said:
39084723-HVAC is not compatible with your BCM
Yes, I know, because it is from a different configuration, but I thought it could be replaced like that, now I understand everything, it can be replaced but only from the BCM that supports a given configuration, am I thinking correctly?
  • Replies 834
  • Views 68.3k
If the calibrations have the same size and internal lenght should works, but if are different, programming fails, compare 2 calibrations 20 - HVAC and you can see the size difference
Yes, I see now, thank you
Anyone able to take bcm cals for that vin W0VBF6EH8LG020278 ?
W0VBF6EH8LG020278 bcm.zip
W0LPF2EZ9FG000626 PİN CODE : 4054
W0LPF2DC0FG003654 PİN CODE : 1774
W0LPF2EZ9FG000626_BCM.zip W0LPF2DC0FG003654_BCM.zip
I would like to request calibration files for :
Vin :W0LBD8EC9G8083470
Module : K9, BCM
Thanks in advance
  • Popular Post
W0LBD8EC9G8083470 PİN CODE : 6050
W0LBD8EC9G8083470_BCM.zip
I appreciate this very much, Thank you!
Hi. Opel Insignia 2013, can someone help me find calibrations for IPC?
W0LGT8ENXE1008471
W0LGT8ENXE1008471 pin code : 4361
W0LGT8ENXE1008471_IPC.zip
If someone can help with calibration files and XML configuration file for :
Vin :W0LBF6EK2GG056574
Module : BCM ,K9
W0LBF6EK2GG056574 PİN CODE : 1833
W0LBF6EK2GG056574_BCM.zip
Thanks a lot!
Thanks. Can you also help with XML file for IPC?
ipc.Txt
ipc.Txt
XMLFile.xml
Hello
I need ECU calibration and PIN for Astra J 2013.
2 hours ago, Enterlan said:
Hello
I know is easy to post picture of VIN, but should be posted as text. Not to mention where is separate theme for PIN requests…
W0LPD6ED7E1054526 PİN CODE :2145
W0LPD6ED7E1054526_ECM.zip
Hello gentlemen!
Is it possible for someone to acquire files for K1 14V power module for 1G Ampera/Volt?
Info log from DPS is attached:
K1.txt
21 hours ago, pupu14 said:
Hello gentlemen!
K1.txt
K1 2012.ZIP
Hello. Help with engine control unit calibration K20 KL4AMDSL7SB051343.
