Hello All,
I want to start by thanking everyone in this amazing community for your incredible efforts and helpful shares.
I need a modified File for a BCM BOSCH 70f3558 + 24c32
BTV + Sport Mode
If anyone has a tested working file.
  • Replies 834
  • Views 68.3k
Hi guys, I want to add a CE1 option (rainsense wipers) to my Chevy Trax 2018.
If its true, there is no such as function on Trax 17-22 cars, but im not sure, so i find a similar VIN from Encore with this rainsense option. If somebody can help me with BCM callibration files from my car. Read info file attached. And also i need a BCM files from next VINs . Thanx
KL4CJGSM3KB871012. this Encore from 2019.
or Mokka W0VJD7E82J4205416 this car is 2018
GCI_Log_bcm_trax.Txt
  • Popular Post
The SPS I'm using doesn't support this VIN.
I think GM Techline is needed.
I don't own this account my friend
ı already send you password pm brother
KL4CJGSM3KB871012 zip password
W0VJD7E82J4205416 zip password
Hello. Please help me find the VIN number for Wolpd8ek408033939. Thank you
Could you please specify what you want?
and Please check the VIN number.
W0LPD8EK408033939
@hassan77h , Security code for the BCM unit
W0LPD8EK4D8033939
Yes, that's correct now, because the VIN number you wrote above is incorrect. The one in the picture is correct.
W0LPD8EK4D8033939 pin code : 0594
@hassan77h Thank you very much
On 6/20/2026 at 9:41 AM, hassan77h said:
Thank you very much for sourcing and supplying the files.
I updated the first Astra successfully.
Can You help me again with the other files - no need to hurry:
K43 EPS calibration+setup for: VIN: W0LPF8EN8E8015224 $CB: 13414033 $CC: 13394503
plus
K41 UPA calibration+setup for: VIN: W0LPF8EN8E8015224 $CB: 22810361 $CC: 22810365 UD5
plus
K109 FCA calibration+setup for: VIN: W0LPF8EN8E8015224 $CB: 23179697 $CC: 23179697
and for playing around:
A20DTH with speed governor and 1 EGT sensor
K20 ECM calibration+setup for: VIN: W0LPF6EN3DG015706 $CB: 55585024 $CC: 55573121
K20 ECM calibration+setup for: VIN: W0LPD9EN0D2004487 $CB: 55585024 $CC: 55573121
A20DTH with speed governor and 2 EGT sensors
K20 ECM calibration+setup for: VIN: W0LPF6EN0DG114631 $CB: 55590420 $CC: 55573121
K20 ECM calibration+setup for: VIN: W0LPD9EN0D2088875 $CB: 55590420 $CC: 55573121
Cheers,
Toby
  • Popular Post
I'm trying to provide the requested files to help people. I see the files being downloaded repeatedly, but for some reason I don't see a single like.
Of course, I respect my friends who like the files.
But if this continues, I will stop sending these files.
All the other files are here, brother.
W0LPF8EN8E8015224 PİN CODE : 4836
W0LPF6EN3DG015706 PİN CODE : 8728
W0LPD9EN0D2004487 PİN CODE : 0579
W0LPF6EN0DG114631 PİN CODE : 4946
W0LPD9EN0D2088875 PİN CODE : 8668
W0LPD9EN0D2004487_K20.zip W0LPD9EN0D2004487_K20_SETUP.zip W0LPD9EN0D2088875_K20.zip W0LPD9EN0D2088875_K20_SETUP.zip W0LPF6EN0DG114631_K20.zip W0LPF6EN0DG114631_K20_SETUP.zip
  • Popular Post
@hassan77h
4 hours ago, hassan77h said:
Estoy tratando de proporcionar los archivos solicitados para ayudar a la gente. Veo que los archivos se descargan repetidamente, pero por alguna razón no veo ni una sola me gusta.
Por supuesto, respeto a mis amigos a los que les gustan los archivos.
Pero si esto continúa, dejaré de enviar estos archivos.
Aquí están todos los demás archivos, hermano.
W0LPF8EN8E8015224 CÓDIGO DE PÁN : 4836
W0LPF6EN3DG015706 CÓDIGO DE PENSIONES : 8728
W0LPD9EN0D2004487 CÓDIGO PÁN : 0579
W0LPF6EN0DG114631 CÓDIGO DEL PÁ� : 4946
W0LPD9EN0D2088875 CÓDIGO DE PÁN : 8668
I think I'll also start password-protecting the zip files I share in the thread... and only sending them to the requester.
Thank you very much for your precious work.
I can totally understand your comment.
Lyubomir, hassan77h and Arbe_gtc
you are the top posters and in my eyes the problem solvers for all the requests here.
The little most you can expect is a like and a comment of thankfulness. 👍
Thanks again and please don't stop your support helping guys in need.
Hello, can someone please help me with these files?
W0VBD8EG0K8003539 - K43 EPS (config) CB 42525149 CC 42525149
W0LBE6EK4GG045854 - K74 HMI (calibrations) it can be any hmi 2.5
Thanks in advance!!!! Will like your comment ;)
what is HW for HMI and do you need with or without UVC
  • Popular Post
Hello.
I would like to receive BCM CALIBRATION for the 2016 CADILLAC ATS 2.0T.
this is my first time, I am not familiar with the rules. If there is any additional information I need to obtain the file, I would appreciate it if you could let me know.
THanks in advance
VIN : 1G6A91RX2G0126888
1
13510534
2
84058172
23351126
3
23353670
4
84087554
23353701
5
23351102
6
23378581
11
84058199
15
23213088
16
13505709
17
13505710
18
13505707
19
22944382
20
84058164
  • Popular Post
5 hours ago, chicking said:
Hello.
THanks in advance
1
13510534
2
84058172
23351126
3
23353670
4
84087554
23353701
5
23351102
6
23378581
11
84058199
15
23213088
16
13505709
17
13505710
18
13505707
19
22944382
20
84058164
K9 BCM 1G6A91RX2G0126888.zip
Hi everyone,
I'm looking for a BCM file ( 70F3469+95160 ) for the following vehicle:
VIN: W0LPD5DD7GG129205
The BCM should have BTV and Sport Mode enabled.
If anyone has this file or can help, I'd really appreciate it.
Thanks in advance!
Hello, guys, I need next standard and few additional IPC files for KLAJA69ED9K132666 (&UDB -FX3 -ATH &J60 13309855):
Part
CVN
LANGUAGE CONFIG
0000AB61
13309857
Database-Driven HMI(DDH) Calibration
0000C88A
13309851
O/S Air Temperature Calibration
N/A
95224386
Overspeed & Biasing Calibration
00001152
94567418
Transmission Configuration Calibration
00001C45
94567417
Warning Calibration
00007AD1
95971941
Indication Calibration
0000FF03
94567411
Lighting Calibration
00005140
94567399
Performance Calibration
0000BF6B
95971944
Operational Software
N/A
13309855
And additionally next parts:
94567420 -? in report
94567414 -? in report
94567394 -? in report
95971940 &FX3
95987416 &FX3
94567407 &ATH
Thanks in advance 🍻
