  • Popular Post
  • Replies 834
  • Views 68.3k
@hassan77h thanks friend and thank you for everyone.
hi can someone help me with bcm calibartion and immo calibration for vin KL8CD6S9XFC725542,
THANKS
hi my friend
alatka asd and jorgecostacv
I tried, but I'm getting a "VIN not supported" error. I think GM Techline is required for this VIN. But I don't have that service.
If anyone has GM Techline and Holden SPS, and they share it with me, I can download all the files and help everyone.
Because I've noticed that many VINs that support Holden and GM Techline require calibration files.
best regards
Hi everyone,
I'm looking for TCM stock calibrations file
VIN: KL1PJ5C63AK594928
Thanks in advance!
54 minutes ago, hassan77h said:
Cześć mój przyjacielu
alatka asd i jorgecostacv
Próbowałem, ale pojawia się błąd „VIN nieobsługiwany”. Myślę, że GM Techline jest wymagany do tego numeru VIN. Ale nie mam dostępu do tej usługi.
Jeśli ktoś ma GM Techline i Holden SPS i podzieli się nimi ze mną, mogę pobrać wszystkie pliki i pomóc wszystkim.
Ponieważ zauważyłem, że wiele numerów VIN obsługujących modele Holden i GM Techline wymaga plików kalibracyjnych.
Z wyrazami szacunku
Okay, I understand—thank you. Maybe someone has access and can manage to get that PIN code.
6 hours ago, alatka asd said:
Hello everyone :) Is it possible to get a PIN code for VIN 5GAEVCKW2LJ133854? Thanks in advance :)
try 7122
THANKS
Hello sir.
I would appreciate your help in obtaining the BCM(K9), IPC(P16), HMI(K74) calibration files.
VIN No : W0VZT6EBXJ1054886
thanks in advance.
10 minutes ago, chicking said:
Hello sir.
thanks in advance.
W0VZT6EBXJ1054886_k74.zip
30 minutes ago, Camelot said:
thank you Camelt.
If possible, could I also obtain the BCM and IPC files?
Hello, can someone get two security codes for these two clusters?
W0LBF8EG9G8106081 - UDD
$CB- 39042935
$CC- 39042935
W0VBD8EG0K8003539 - UDC
$CB- 39187109
$CC- 39187109
Thanks in advance! Will like your comment 🍻
  • Popular Post
  • Popular Post
here Adelin
W0VBD8EG0K8003539 pin code : 8202
W0LBF8EG9G8106081 pin code : 5245
@hassan77h thank you so much. 1
@blocked
22 hours ago, blocked said:
hi thanks for the file but i need the Type4 files information into the “SPSToolBridge.LOG” file. to make the type4 dps. thanks for immo
Hello.
I would appreciate it if you could provide the IPC CALIBRATION Files and setup files
for VIN NO. KL1PM5C61EK615725.
VERY Thank you for your continued assistance.
52 minutes ago, jorgecostacv said:
@blocked
log.txt
here chicking
KL1PM5C61EK615725 PİN CODE : 5610
Could you please send me the K17 and K20 gci.log.txt file for this vehicle?
KL1PM5C61EK615725_P16_SETUP.zip KL1PM5C61EK615725_P16.zip
