i have checked ,
sorry
which i have its 2023 Blazer 2.0L engine
  • Replies 834
  • Views 68.3k
Hello, can someone get ECU and BCM Files VIN: W0VBF6EH8LG020278 ?
Thanks for help
hi any one is possible have pin frrom this vin 3GNAXNEGXPL212492.
thanks
I NEED CAL , CONFIG CRUZE ECU SIMTEC 76.1
VIN KL1PJ5CE7DK088546
thanks
pin readable on bcm
thanks
6584
1 hour ago, Arbe_gtc said:
6584
Thank you
@SHARAWI Give GCI log from DPS.
hi is possibel some one help me with type4 files from sps vin 3GNAXNEGXPL212492 ??
thank you
@Autobitas thanks
Looking for calibration for radio part number 13596605 FIN 3GYFNHE35DS583798 Europe
Thank you very much in advance :)
Please check that the calibration files are correct. I downloaded them as standard programming.
3GYFNHE35DS583798_RADIO_PROG_ORJ.zip
Can someone get holden Files from a Astra k ?
@tobiasp I just saw your message. If you can send me the gci.log txt from the ecm and bcm modules, I'll try to help you.
Hi, thanks. I have no log file. I need only the Files for tests.
Hi can any one help me with vin to pin
2GNFLFEK2G6169556
2GNFLFEK2G6169556
Guys i need your help
anyone please get me 2020 camaro Cluseter (UHS) xml and built file
1G1FH3D75L0102578
THanks.
NEVERMIND I GOT IT
hi i need cal for ecu & tcm
6G1EK54W39L239268
ecu GCI_Log.Txt tcm GCI_Log.Txt
KL1PM5C69AK515074 can any one help me with calibration and pin code for ecu and bcm . Thanks
Hello, here are the files for BCM.
BCM_bin_CRUZE.zip
good day, can someone help with calibration files for VIn 3GNAXKEV1NL184639 A11 Radio IOR PRO? Thanks.
3GNAXKEV1NL184639 A11 Radio.7z
