Harman 3X Calibration info
Hi guys, i have various firmwares from Harman 3X and extracting it, i found this. I think its the functions of all calibration for the harman radio.
Are totally different to the HMI 2.5
The most of the files are XML files.
the file CalSets.db can be opened on net: https://inloop.github.io/sqlite-viewer/
Someone know how working the calibrations in this radio? how to edit the calibrations? for example, to change the boot animation
by the way, the info 3 system are based in Android.
Harman_Info_3X.zip
  • Replies 119
  • Views 13.7k
  • We start!
  • In car working...
  • I have info3.6 but it's for global-B sitting in the states. I will try to source a info3.6 Global-A so I can join this party.  Following.
  • I have from an astra k the gateway and can load the 3.0 and the 3.5 hmi
  • No problem.
  • if you put a 120 OHM resistor in the HS speed wires of the radio, you should communicate without the serial gateway module This: Mouser REF: 829-15429045 Fabr. N.º: 15429045 Fabr.: Aptiv (former
Hello, attached example calibrations of three random vins without the utility. one of Info3, one of Info3.5 and one of Info3.6
3X_Calibrations.7z
Order of the calibrations
 2: Radio
 3: Hybrid
 4: Salesmake/Brand
 5: Language
 6: Speech Recognition
 7: Hands-Free Tuning
 8: Rear View Camera
 9: Common
 10: HVAC
 11: Telematics
 12: Optional Equipment Calibration 1
 13: Optional Equipment Calibration 2
 14: Optional Equipment Calibration 3
 15: Equalizer
Hi guys, i have news. the .bin files i atached in the previous message, can be uncompressed again using 7zip and the new file is the XML in plain text.
I think this clear a little bit the way to edit the files....
Any help with this is good recived.
2 minutes ago, KZV said:
calibration signed
changes are not possible
without disabling digital signature verification
bad news then...
Im waiting receive an info3 and an info3.6 to do proofs...
well, someone have a european/russian VIN (not Opel) from a Global A platform model with info3.6? im searching but no find nothing...
Which vehicles had those?
I can look for VINs at local car selling portal..
I think Chevrolet Tahoe, and traverse and in cadillac, the ATS, CT6 and CTS are Global A
I have already found a VIN info3.6 from Russia. and i have the info3.6 in house. I'm waiting the screen to starting the proofs with the calibration  files 🙂
Following.
Following.
My unit is global A. at the moment i have communication with DPS, and GDS2.
There are new cars still in global A platform, Acadia, blazer... (but few in europe with info3.5 or 3.6)
and there are a tool called "CalDef Tool Suite" to create calibrations. but this tool i dont think we can get it easyly...
We start!
Seems safe to swap calibrations of different cars
Its 100% an android system based. you can enable the developer options and the usb debugging can be enabled too. maybe this can be used to connect by adb to computer...
The ADB its locked:
e:\platform-tools>adb devices
List of devices attached
AGUF4R31e752c4  device
e:\platform-tools>adb install filemgr.apk
Performing Push Install
adb: error: failed to copy 'filemgr.apk' to '/data/local/tmp/filemgr.apk': remote
The Secure ADB mode is enabled. Please use the GM Secure ADB Client tool to authenticate first.
filemgr.apk: 1 file pushed, 0 skipped. 619.5 MB/s (5536292 bytes in 0.009s)
Well, I have managed to get info3 working, and it seems that in the test bench it works fine... I need more tests, but it seems that everything is fine.
the starting animations when opening the door work correctly, removing the key and opening the door shuts down the system....
Now, its possible overwrite the firmware of USA harman by the european firmware? if plug the USB with the european firmware, says invalid...
In car working...
Hi guys
Today i received the usb receptacle with mcr slot and works ok, i have a US card, and im waiting a SD to dump the europe maps
EU Maps working too. 🙂
Anyone have and is willing to share EU calibrations for this type of radio? 😄
360 video and bose sound system should also be added.
yes, its possible. loading the calibrations with this extras. but for 360 video need an additional module
Yes, I know, it is necessary to use the module for 360
How did you pack the calibrations ?
You mentioned a program called cal def tools, did you find it?
No, i cant find this program
You can do packages normally using other cars calibrations, and this works.
I got it, man I'm waiting for the modules, I'll do a few trials, I'll try for 360 vision and bose sound.
Mateusz Lorek Pasha OpelGuy BLKATSG Pavel Cleberson Santos Arbe_gtc Miragui pako rockdriguez Garik67 VADZIM sigmaxxx Mohammed Aljack SHPSHP Lorenzo Barrientos Adelin alatka asd ViCo2 Shifty John Stevens
