Harman 3X Calibration info
I have from an astra k the gateway and can load the 3.0 and the 3.5 hmi
  • Replies 119
  • Views 13.7k
  • We start!
  • In car working...
  • I have info3.6 but it's for global-B sitting in the states. I will try to source a info3.6 Global-A so I can join this party.  Following.
  • I have from an astra k the gateway and can load the 3.0 and the 3.5 hmi
  • No problem.
  • if you put a 120 OHM resistor in the HS speed wires of the radio, you should communicate without the serial gateway module This: Mouser REF: 829-15429045 Fabr. N.º: 15429045 Fabr.: Aptiv (former
Great i found from Insignia and Astra as well,will buy it tomorrow do i need bcm connected also?
i dont have any wiring for the gateway how do i connect it ?
I can give you the wiring. I thing you need no bcm
Many thx i will send you PM, i will try without bcm first
No problem.
7 minutes ago, tobiasp said:
No problem.
Thx pm sent
thx gettimg error on the pm so cant read anything you sent today
This:
Mouser REF:
829-15429045
Fabr. N.º:
15429045
Fabr.:
Aptiv (formerly Delphi)
In opel Insignia you can find it behind the speedometer. Whenever I go to the junkyard, I always take several resistors with their connectors. They're very useful, and they're very easy to remove.
Thx
I can also see no messages. Here comes an error messages at all pm's
Good idea on radio two simple resistors 120 ohm and i think it works whitout Gateway
This:
Mouser REF:
829-15429045
Fabr. N.º:
15429045
Fabr.:
Tested to put one 120 ohm on the 6/14 pins on the obd plug but i get same error
In the screenshot you shared can see this:
Number of detected programable ECUs: 0
Put pin28 X2 to +12 and try again
Thx X2 is same connector as the can wires run to right?
X2 it the connector of the speakers
X1 is the connector you have the power and gnd
Tested +12 v on pin 28 X2 but have same error , the 120 ohm is connected to the obd wires pin 6/14 so maybe i will need gateway anyway?
4 hours ago, tobiasp said:
Hi got my gateway now but i the wiring it says X2 pin 23 , mine have 2 connectors but only 16 pins on each?
Check the prog text , it says found ECU 1 so im thinking it most be a bad unit? (bought from china) ProgramLog.Txt
On 11/6/2025 at 4:04 PM, Arbe_gtc said:
if the radio dont have the wireless acces point enabled, wireless carplay-android auto not works
So I have 2020 model year which does not support wireless Android Auto, but the Hotspot is working fine. Would it be difficult to active wireless AA?
Mateusz Lorek Pasha OpelGuy BLKATSG Pavel Cleberson Santos Arbe_gtc Miragui pako rockdriguez Garik67 VADZIM sigmaxxx Mohammed Aljack SHPSHP Lorenzo Barrientos Adelin alatka asd ViCo2 Shifty John Stevens
