Hello! I need ECM calibration files for Chevrolet Cruze
VIN: KL1JF35L9DK015503
Calibration file nr1 is 55588355
My SPS don't want to connect via this VIN...
Thanks!
  • Replies 834
  • Views 68.3k
On 9/7/2024 at 16:18, Lyubomir Krastanov said:
xin lỗi, nhưng số VIN đó không được SPS của tôi bảo vệ
Thanks!
Thanks!
mine as well, is a Korean more likely...
On 6/30/2024 at 7:18 AM, Lyubomir Krastanov said:
To entry controller without having actual one I need Base and End model numbers. Not always is available. In some cases I need to know and current OS/Calibration part #1.
Dear @Lyubomir Krastanov
can you help me to get IOT calibrations?
VIN: W0VZX8GS1N1000900
39180555
7310500000000X
555343750
H119085300001484
S/N: 903786168
Regards
39180555
7310500000000X
555343750
H119085300001484
S/N: 903786168
Regards
currently I don't have hmi 3.x to allow me to write emulation. Need to source one soon.
39180555
7310500000000X
555343750
H119085300001484
S/N: 903786168
Regards
Something not match
The VIN have IOU Radio, but the numbers you shared is a 2019 R4 Radio  IOB...
can someone help me with calibration files for IPC 8" display for vin W0LGT8E58G1032545?
Thanks in advance
Thanks in advance
Did you have this display on hand?
I already fitted to my car, original was the one with small lcd
Then provide me screenshot from GDS2 or DPS with all information for that cluster (eg. Base and Part numbers and current calibrations).
11 hours ago, WhiteAndBlue said:
unfortunately u need custom files made, as car doesn't come with UHS cluster. U simple need to rework XML file to enable/disable what optio  you don't need. Might need to have some calibration edites as well, but that is away from that post reason to be made
W0LGT8ET8E1028359 this is original VIN number from the UHS display. Can you help me with calibration files? I have security access issue when trying to change something.
make your another post and explain where you have retofit UHS and what need to be disabled or enabled. Someone might help you (for free). I cannot offer free assistance for this unfortunately.
Hello everyone!
Someone can help me activate the video input of the rear view camera for insignia
W0LGT6EM4D1002661
Thank you very much!
Hello, I have someone with an Insignia A20DTH MY 2011, VIN: W0LGT8EM9B1140883
Is it possible to update all ECU‘s with this MY with SPS2? And is there a specific update procedure, or can I update for example first ECM, then IPC, BCM and what else is possible.
thanks in advance
I need A11 calibration Navi950 W0VWT3D64KG376329
Hi!
Im searching the calibration number
12823220, Local Globaltis dont have it (only 12823221)
SAAB 9-5 2010-11
if someone have it, can share it? Thanks!
Hi.
SAAB VIN YS3GP4AL4B4001358 has that calibration number. Camera was retrofitted and Radio programmed with VCI code. If someone can get you the calibration from SPS with that VIN...
Factory origianl Radio is with RPO:
UXY   RADIO AM/FM STEREO, NAV, DVD-ROM, CAF, HDD, USB RSA, RSE, TMC, (GME VERSION)
Your VIN has :
UYS   RADIO AM/FM STEREO, NAV, DVD-ROM, CAF, HDD, USB RSA, RSE (GMNA VERSION)
Dont know if that matters though. 🙂
im installing a 2011 version of Saab TIS to check if this calibration are available...
Same..
In the database the calibration 220, not appears
thats probably because as far as I know the rear view camera option became available with MY12. Maybe I am wrong. But if you have MY11 GlobalTIS then this calibration can not be there. Do you have SAAB Online SPS? I have but how could I check the calibration availability?
Then probably didn't have the camera option until 2012, but GM killed saab around that year.... No, I don't have access to the SAAB TIS Online.
Hi.
I'm looking for calibration.
Holden Astra K BCM
VIN: W0LBF6EH4HG072944
