2013 Camaro Electronic Power Steering calibrations files request
1 minute ago, Charly LSG said:
SPS2 choose automatically I have no choice and the DPS pics was before the reflash (actual state from factory, I always take a pic before reflash ...)
That's what it should have done, and definitely your VIN?   You didn't use a friends VIN or anything right?
  • Replies 78
  • Views 5.6k
    As expected. Issue coming from calibration file. That file is not stated in SPS info. No idea how Techline have distributed this for you.
    I understand. For further assistance I need to make diagnostic to vehicle (remotely) as will be expensive to come personally
    To get correct files you need to state your VIN. As well for brick situation I presume your car been not on BSU/voltage support and drop. That might kill your module. Have few options in your case. U
Yes sir my VIN and only my VIN, I called techline connect assistance in Europe today to explain my issue. No one is able to explain me the issue, I think about a compatibilty problem between SPS2 (latest cal.) and my module. I ask them to send me an older calibration to download my module. To be in the same shape like before trying to update with the latest cal...
I also try to call AC delco helpdesk in US and when I explain my issue, the guy cut the phone ...super service from them.....
It *is* possible that your device is having an issue programming similar to our SDGM one Lyubomir and I were helping someone with.  Let me try to package this and I'll get you to try with DPS again and then get me the DPS log.
thank you sir 😉
nice of you
2G1F91EW0D9105970-EPS.zip Load up DPS, Select that archive, I don't know if it's on the low speed (pin 1 - 33.3kbps) or high speed (pin 6 & 14 - 500kbps) but try high speed first and see.  If it gets as far as OP CODE 10, pull the DPS log for me and post it here.  If it fails right away, try the other bus.  I can't remember off the top of my head which one it's on.
I did a trace on SPS, it looks like it's on the HS bus.
yep sir, I will try it few hours  ( i'm not near the car right now, just my laptop with me) and let you know 🙂thank you sir
@codebuilder EPS is on HI CAN 6/14
1 hour ago, KZV said:
there is another strange thing
the SEED of the part has changed
this could only happen for two reasons
  1 EEPROM was destroyed during programming
  2 are two different parts
I spotted that too........  that's why I asked, is it the same module?   Something is very strange here.
@codebuilderi just try and same error at 47% here is logs sir 🙂
EPS ProgramLog.Txt EPS Read controller info.Txt
Not the same year model but interesting to read ?
GM bulletin.pdf
That reffer to ecm/tcm and they have different structure and procedures.
It's really strange but basically it's uploading the routine, then the OS, but the it's failing on the first calibration.  For whatever reason, it's not accepting it.  I know I sound like a broken record but you're absolutely certain that this part was never swapped?  Lyubomir and I have been talking, he might be able to build another one for you to try (I can't access those in NA).
@codebuilder
@Lyubomir Krastanov
 Hi, the only part I swapped on this car was to put a brand new (from GM official) blank BCM and program it via SPS2.
Because an erratic functionning from the BCM about exterior lightning.
The programming was a success with the new bcm (the power steering was working normally).
The EPS module was on the car when I bought it, no swap from me and when I got the car the Power steering was working normally before trying to reflash it to get an update cal.
The only other strange things I remarked after putting the new bcm and programmed it, is that when I started the car I have 2 messages in the driver center info  that I never saw before
- Service adaptative cruise control
- Service Active steering system
There is no Adaptative cruise control and no Active steering on this car ??? it's on GEN 6 Camaro not GEN 5 like mine.
Perhaps my EPS reflash issue is "linked" to this trouble ?
Perhaps SPS2 send a wrong update files (like the GEN 6 Camaro or newer ) in the BCM and after that automatically when in trying to reflash the EPS, he send a wrong file which is incompatible with this kind of steering module ?
Do you understand what i'm trying to explain sir ?
I see an error why the calibration is not loading
but how it got there is very interesting
do you have the same file numbers
but only before you unzipped them for DPS
look in the SPSCACHE folder
Check him VIN in SPS info and will see where that Calibration part file is not listed. Him use Techline (AcDelco). Him suppose to use PSA
exc11 Enterlan MarcinFromSaturn Jaydog
