2013 Camaro Electronic Power Steering calibrations files request
@codebuildersame part number sir
  • Replies 78
  • Views 5.6k
    As expected. Issue coming from calibration file. That file is not stated in SPS info. No idea how Techline have distributed this for you.
    I understand. For further assistance I need to make diagnostic to vehicle (remotely) as will be expensive to come personally
    To get correct files you need to state your VIN. As well for brick situation I presume your car been not on BSU/voltage support and drop. That might kill your module. Have few options in your case. U
That seems weird.  Can you pull the calibration numbers from DPS or GDS2?  Just curious...  It seems so strange.
Issue is not correctly build archive and dead module. To load calibrations need to be loaded directly with something like IO terminal
Yeah I see that too, just with even before getting that far in the DPS log, I saw the ECU's responding negatively which almost told me the vehicle was running lol.  But if they were wrong, it wouldn't matter anyways as it'll just fail later.
exc11 Enterlan MarcinFromSaturn Jaydog
