Eqinox 2018 ebcm change pin
Hello guys, who can help me remove the C0460(5A) error in EPS?
  • Replies 53
  • Views 4k
  • Last_Captain
    Last_Captain
    as you like, no problem, good luck2018_Chevrolet_Equinox_EBCM_Calibrations.zip
  • Big thanks Troy I figured it out
  • B3902-00 means Wrong Immobiliser Identifier received:
  • Last_Captain
    Last_Captain
Hello comrades, is there really no software solution for this problem?
Does ECU sees measurements from position sensor?
Have you done sensor learn/recalibration?
If everything is in working order, DTC should disappear automatically after a few minutes of driving.
If not - recheck if your repairs were correct.
Hi, ECU does not see the measurements
Grease Monkey GivemeurPCM Andy_san vavan Autosys ELTOKE Redsupra Arbe_gtc OP exc11 Emmanuel Koomson zhilwe aleks nik greyworm A61bk Iraldo Almaguer Jaydog felipe vargas AL RAED Flash
