Automatic Heated/Cooled Seats
Solved by Robi_X
On 3/2/2024 at 7:42 AM, codebuilder said:
 I’m sure we could figure out the sport mode button
I and @Arbe_gtc figured out the Sport Button thing. Tomorrow i will try out what i build.
On 3/2/2024 at 1:28 AM, codebuilder said:
Ok so I’ve found the flag
Where would that be, probably in cal 20?
One thing to understand, Your car shows also "Auto Cooled Seats" in climate Settings or  just  "Remote Start Auto Cool Seate" in Remote.... Settings?
  • Replies 64
  • Views 4.9k
  • BCM calibrations alters the radio menus, yes
  • @Robi_X     HVAC module facelift and calibrations from Astra K 2021 AGR + QuickHeat. As I still have to install the AGR seats, and change the navi900 intellilink to the Info3 s
  • Looks like it work on Pre Facelift Astra like it should.😄 Current tested Car's: 2016 1.4 Petrol  2017 1.6 Petrol   Also is now the HVAC Menu working (after HMI enable)
It's in #5, there's actually a bunch of cool things you can do in there.  It says Auto Cooled Seats but it's under the Remote Start configuration.  You can hide/show heat or cool with remote start too (can't remember where the heat flag is off the top of my head though).
Ohh more hidden features?  Do you have you BCM file by hand than can i have a look
I have to try the BCM calibrations of the 2019 Malibu, because they are very similar to the 2019 Astra K, to see if any new options appear in the HMI menu
Did you activate Teen driver or was this one already active?
Teen driver has activated after load malibu calibrations, same as auto cool and auto heat
Maybe i misunderstood something but is the auto feature only in "Remote Lock, Unlock, Start" or also in "Climate and Air Quality"?
Because Remote Start is not an Options in my Car (Manual Transmission).
i think auto heated seats option inside the Climate and air quality menu, are dependent of the HVAC calibrations..
the Envision uses the same HVAC module than your Astra K
(13598154) replaced by: 84234763.
maybe we need check the hvac calibrations in Envision model...
I have the HVAC Cal one Stock and the other with Quickheat
HVAC with QH.zipHVAC without QH Org.zip
Dont know if it helps🤔
Loaded Envision 2018 calibrations in my 2019 astra K module (uses the same number module 84295139) image.png.1584b0bbf8c18c5852387f5aeecb5a49.png
Check if your calibration 01 is this: 84234770
Yes, Cal 01 is 84234770.
i sent you the hvac cals. the option i think is in the number 03. but have a lot of differences... try to create a package only changing the number 03 and test it
In my case, I've found them in HVAC Calibration 03 (HW: 13591958, OS: 13594173) by compare with 2014 chevrolet volt (&KA1) and (-KA1)
but activating 'Auto heated seats' option seems not for rear heated seats (&KA6). works only on front heated seats (&KA1).
offset: 0x48FD, 0x4927 (seems for climate control in mylink screen), 0x492E (seems for climate control in mylink screen)
ref: malibu_2014_C68_LBS_AKX_LHD_C32.zip
I can see similar pattern in 39121643, too. try locate pattern like: FF 12 13 14 FF. I found them around 0x48F9~494A.
uff... right heated seat malfunction (high resistance)
Yes, it's only for front seats
Dose someone sits on the Right seat?
Only if someone sits or seats buckled it turn automatic on.(And cold enough)
8th gen malibu (2012~2015) in korea have no passenger presence sensor and seat belt reminder for all passengers (only for driver). and nobody seated on the passenger seat.
both front heated seats turned on right after engine start.
but passenger heated seat turned off after 10 seconds with DTC. (passenger heated seat malfunction - high resistance) it also turned off automatically when I turned on the passenger seat manually)
I think I should replace heated seat pad in the passenger seat. 😞
Are  that the resistance is bad? So give him what he wants, and check if the heating works.
@Robi_X
As I still have to install the AGR seats, and change the navi900 intellilink to the Info3 system... I hope it works.
On 3/8/2024 at 10:48 PM, Arbe_gtc said:
@Robi_X
Nice work, I assume the HVAC module in your Astra K is 2016? I got Astra K 2016 and I've already retrofitted AGR seats on it so I'd like to try this calibration out.
I'm planning to do the heated windscreen retrofit at some point so I am trying to find calibration to compare.
my K is 2019 and i used a 2021 module HVAC
I see that in my HVAC control module, the Operational software is below
Operational Software 84234770 00006293
Look like it is compatible?
is different
84692725
and it may not be convenient to try. possible risk of briking the HVAC
  • 6 months later...
@Robi_X
thought I’d return back on this topic as I will be looking into this very soon.
do you have any kind of issues using MY2020 HVAC cals onto MY2019 HVAC such as running at wrong temps, cooling fans not started due to ambient temps?
or everything’s simply working prefectly?
It is probably necessary to replace the HVAC module, but I am not sure if 2020 calibrations can be used on a 2019 module...
 I will look into it. One of the reason I came back to this topic is I was trialing out the climate menu feature on Astra K which I discovered some ways. I used a method that you did by programming MY2020 calibrations into earlier MY2018 which it was successful in terms of the climate menu, although the temperature is quite way off along with cooling fans wasn't functioning.
It is strange as I tested MY2020 Calibration from other buick vehicle and it was working prefectly, although it was missing C32 Quickheat and KU1 cooled seats, which I tried and do the custom editting on the airflow calibration and it just doesn't want to work after each byte.
M Ch chrissmara Adelin chicking Thamer Mo WSOpel tobiasp John Stevens exc11 Enterlan Robi_X pupu14 bekatsilosani Arbe_gtc bondarrenko crakavelli uglyoldbastard JBL_1989 Opelinsignia1985 codebuilder
