Calibration ipc cruze
Could you help me turn off the TPMS IPC Cruze?
  • Replies 52
  • Views 4.2k
  • E-Ing-X20XEV
    E-Ing-X20XEV
    Hey, regarding the autowipers... Have you tried to enable the indicator via 0xA6 Byte 1-Bit 0 configuration DID?   0xA6,0xE6,0x8A,0x30,0x90,0x8A,0xEE,0x1F, 0xA6,0x00,0x01,0x02,0x
  • hello, i have get new ipc vin 2011 china is: LSGPC53R3BF000379   ipc_ltz_cn_2011_final.zip
  • i'm check  with FX3 then different is: Indication Calibration 95989747 Unknown Warning Calibration 95051419 Unknown
On 1/1/2024 at 21:55, tungnv93pt said:
Xin chào,
Tôi đang mua ipc cruze 2009 china và flash module ipc 2011 nhưng không thành công. Tôi đang thử flash lại hiệu chuẩn gốc nhưng không thành công
Tôi nghĩ là có vấn đề về phần cứng?
e2.Txt 304,63 kB · 12 lượt tải xuống
mongoose cable doesn't seem to support IPC flash
aaronprg ABOMAZEN chicking kobrak16 alatka asd Daniil_Ast Obada Alrifaee Abraham suarez Zafar_ VNautorepair Slava Colpak Rusnet1 SHARAWI exc11 antonsteering dogwulf
