Chevy Bolt(Opel Ampera-E) K56 Serial gateway problem
Solved by codebuilder
  • Replies 109
  • Views 13.2k
  • I think I can try something else reduce the length of the transmitted packet I read somewhere that NANO has problems with the buffer size
  • mikko virta
    mikko virta
    And it was succes mdiClone_serialB_works_pin1_33kb.Txt
  • There is some weird/missing data in GDS2 log too.. Communication issues are totally not out of the question here!   OP, is your MDI2 original? Try updating MDI software and firmware i
happy days and all of us learn for issue with vxnano and Gateway module. Thank you sharin all info with rest of us.
Need to mention that you guys here was making me feeling like beeing at group where people really want to solve problems.
So big thanks to you.
Exspecially @Lyubomir Krastanov how was spending long night with me on time when i was most desprate.
But for reprogramming. I was following those steps for getting and maintain deep sleep before and during reprogrammin of Gateway module. I dont have any clue, what might happe if not following.
Also need to mention that after doing Serial A and then B then i  wait that 5 minute period what is also mentioned that document.
Awesome, thank you for the update!  So the MDI worked but not the VCX?
Yes, VCX NANO is definetly "killer" for Serial Gateway B.
Maybe in future there will be more modules what are suffering same issue(pin1) on re-programming CanLo over J2354 or maybe VXdiag will fix firmware based on that bug report....
Lucky for us(Owners of VCX nano) that CanHi seems to work robust 🙂 because there is the modules what usually needs to reprog
Brutal!  haha.  Yeah, once I tried it and saw the same thing, I had a feeling.  I have a different way I could likely get it programmed but I might actually try another device that can do Global B.  Not that I *really* need it.  I knew there had to be a flaw somewhere in the VCX though.  It's been impressive and done 99% of what I've needed it to do.
  • 4 months later...
Just an update for this post, I did figure this one out later.  It is an issue with the VCX but there is a fix for it.  I know it's programmed now but if it comes up again, or with other modules.
Hello, can you please share what the solution for VCX Nano is?
Shifty GMcars karolputowski lvulcan Samm Dano rickc BlacKICE ibrahim Murad DaOneDuc tobiasp Rui miguel mcOreos
