Adaptive Cruise Service Message
Solved by codebuilder
On 10/1/2023 at 12:43 PM, codebuilder said:
Ah it took me two seconds.  This one will turn of TPMS if you ever don't want to see it (winter tires).  If you want it back on, flash that other file back in (note: may have to enable in the pages menu)
Hi there! Is there any chance you could do the same for me? I have an IPC from a 2017 Acadia Denali and need to clear both the ACC and TPMS errors from the programming.
I did try the uploaded file, however the cluster doesn't respond properly (it isn't bricked though, flashing is still possible. The part numbers must be different.
The original VIN for the IPC is 1GKKNXLSXHZ187596. Part number is 84152898 if required.
I would be ever so grateful if you could assist 🙏🏼
  • Replies 79
  • Views 7.2k
  • I can tell you that ACC is definitely in one of the CALs as well as the XML.  Did you use the original CALs or are you upgrading the cluster?  If you need, send me your CALs (or give me your VIN that
  • codebuilder
    codebuilder
    It fills the VIN in once doing the writing *IF* the utility sends it (not all do).  For example, the HMI and Radio, you don't need to do this as it sends a different command.
  • codebuilder
    codebuilder
    I used to do the same 🙂
Stock calibrations of this vin
maybe someone can edit to remove your acc and tpms errors
P16 1GKKNXLSXHZ187596.7z
This should do it. Prebuilt ready to upload
1GKKNXLSXHZ187596_NO_TPMS-ACC.zip
You're awesome. I'll test this when I get home from work and will report back.
Thanks again 🙏🏼
Just wanted to say a BIG thank you for providing this file! My new cluster now works perfectly without any errors
Thanks again. It's truly appreciated ♥️
zamich85 Adelin Troll Deryck nev3r Jon Baran penguin4170 exc11 Last_Captain tan tan Ahmed Ali apetrushenko Thomas Crosbie Opelinsignia1985 drstraleman dogwulf
