Type4 applications for GM's DPS
The Type4 Application functionality within DPS allows the user to run a pre-defined software procedure on GM's motor vehicle modules offline without using a GM's online SPS subscription. These procedures typically execute a setup/learn function that requires user interaction. Examples: Oil Life Setup, BPP Learn, Clutch Position Learn, Key Immobiliser Learn, etc.
The file in the web link below can be used to display the Type4 Tab option in DPS.
Change Mileage In GM BCM Modules, Change Mileage In IPC, Speedo
IMMO Program vehicle keys
BCM module removal
ECM/ECU module removal
IPC/Instrument cluster removal
Electronic brake control module learn
Fuel pressure regulator learn
Engine oil life reset
Clutch pedal position learn
CranKshaft position variation learn
TCM Automatic Gearbox/Transmission Fast Learn Adaptation
Brake Pedal Position Sensor Learn
  • Replies 36
  • Views 7.9k
How we can build file Type4 Application from GM Online SPS?
I won’t be creating a type4 tutorial, but maybe later.
For now I focus on creating type4 apps for dps.
very nice thanks
wonderful      good job
YOW
Sacha Baron Cohen Thumbs Up GIF by Amazon Prime Video
Lets Go Reaction GIF от Mason Ramsey😉
hello I have to change an engine ecu and program do you have a file here for this programming?
please...
please...
Hi, there is no VIN changing file for ECU.
ok thank you very much for your attention. i use here and ioterminal for this service.
1 hour ago, sanchouz said:
Hello, these files are suitable for all gm cars ?
Hi, I don't know.
However they should work on gm cars that uses the traditional looking BCM module that looks like one in the attached photo.
6 hours ago, sanchouz said:
Thank you try! I have one file from Chevrolet Cobolt I want to try it on Chevrolet Captiva
You can try it. Type4 apps are safe to use and won’t cause any issues with the modules.
Hi,  How you use type 4 for vin change ? Thanks
Hi everyone, these Type4 files crash on the communication establishing on my system (4.44, 4.45, Win7). Any ideas, what could be the problem?
Also, on Win10 that button is missing. Not sure how to install Techline Connect.
Also, I installed latest Techline connect on my Win10 machine, where button was missing - no effect.
Type 4 apps does not change vin in the modules
On 3/24/2022 at 4:49 PM, sanchouz said:
Hello guys , please tell me to change the vin code , do you need to reprogram the block or is it possible to change it separately ?
type4 apps does not change vin in the modules.
Make sure TLC is install and is able to launch from your acdelco sps account via sps subscription.
The type4 options shows on my windows 10 system with TLC fully install.
Is there another way to activate TYPE4 change contact gm techline?
Niestety po aktualizacji komponentów TLC opcja DPS typu 4 nie jest już dostępna
Unfortunately, after updating the TLC components, the DPS type 4 option is no longer available
Do you have techline connect installed?
Yes, I have the latest TLC Techline installed. After updating to the latest version, the Type4 option has disappeared
blocked kitsaras peter Danielb Dmarvez mohamad connor Murphy Kpeezy Enterlan SHARAWI bassasy Encrypted Owner dumingqiao jorgecostacv SergSanich Tyler Mygrant Ahmed Ali OP
