Type4 applications for GM's DPS
5 hours ago, daroopel said:
Yes, I have the latest TLC Techline installed. After updating to the latest version, the Type4 option has disappeared
@root said he found a solution without needing to install TLC for the type4 option to show up, maybe he can help.
  • Replies 36
  • Views 7.9k
may be mean Techline cache app, not TLC. I no have TLC on main tablet but have Type 4 button.
On 5/2/2022 at 5:34 PM, زياد الخالدي said:
Is there any solution . please help
I've never seen that issue before. Try installing a different version of DPS.
es la instalacion del dps esta corrupta
HVAC Type4 remove. Does anyone have it?
@Hero Tran
Hi guys, i have a problem with any Type4 apps in DPS.
The program close after press next in any T4 app... someone know why? in SPS no problem...
well, its something related with the nativelibs folder.
In other laptop, the local type4 app works ok, but in SPS cant programm online because get this error:
UtilityFileStatus Step = 01, OpCode = 01
UtilityFileStatus Step = 02, OpCode = 27
  00:20:32.6  MsgType=1, <[.H..]00 00 02 52 27 01 [0006] FramePad
  00:20:32.6  MsgType=2, >[.H..]00 00 01 01 FE [0005] ExtAddress TxDone
  00:20:32.6  MsgType=2, >[.H..]00 00 02 52 [0004] TxDone
  00:20:32.6  MsgType=2, >[.H..]00 00 06 52 67 01 D1 00 30 64 06 [0011]
GM 5-byte Security: Algo 65, Chal D100306406, Resp 0000000000 >> Status DLL Other Error
ReturnToNormalMode (0x20) service
if i delete the folder nativelibs, sps download it again, 5 byte its calculated OK and  works but the type4 app in DPS close the program....
Someone have this problem?
Delete sps folder and start fresh legit SPS session to allow to download necessary files. Or copy them from other computer
I have the two folders nativelibs
with one of them, the type4 in local works ok, but the 5seed key online, fails.
and with the other folder, the type4 in local not works and close DPS, but the 5 seed key online, works ok.
very strange.
if someone can share their nativelibs folder... for compare.
too i can swap the folders to works. if i want type4 local, replace folder. if i need program online, replace folder. hahaha
if someone can try dps type4 in local, and SPS1 online.....
Rapid scheme:
DPS Type4 Local OK -----> GM 5-byte Security NOK (GM 5-byte Security: Algo 65, Chal D100306406, Resp 0000000000 ) (in DPS 5B security works ok)
DPS Type4 Local NOK --------> GM 5-byte Security online OK
Look i recorded the problem
someone have this problem too?
Well, the problem is this files:
dllsecurity.dll
tisvcsv4.dll
Type 4 APP DPS No Crash.rar
attached the files. if you have the same problem, make a backup of your original dllsecurity.dll and tisvcsv4.dll, use the files in the RAR to use type 4 menú in DPS.
If you need use SPS, GDS2 again, restore the original files dllsecurity.dll and tisvcsv4.dll
(this files are in "C:\Users\%USERNAME%\sps\nativelibs")
blocked kitsaras peter Danielb Dmarvez mohamad connor Murphy Kpeezy Enterlan SHARAWI bassasy Encrypted Owner dumingqiao jorgecostacv SergSanich Tyler Mygrant Ahmed Ali OP
