How to get cheap GM GDS2 for eternity.
GM has fixed the vulnerability. This file no longer works with the new GM GDS2.
More info here.
Global Diagnostic System 2 aka GDS2
GDS2 is GM's motor vehicle diagnostic software used by auto mechanics to perform diagnostics, including reading fault codes, resetting the vehicle's electronic module and various other configurations.
In order to have access to GDS2,  you have to pay a subscription fee to GM.
In this tutorial, I demonstrate how to pay once and have GDS2 access for eternity.
GDS2 uses two security measures.
1. A hardware ID file name "swkV3"
2. A system licence file.
This tutorial circumvents the system licence file. That's why one needs to purchase a GM subscription in order to obtain the hardware ID file.
Step 1
Purchase a GDS2 subscription for the shortest/cheapest length.
For USA cars, use ACDelco
For European use ServiceBox
Step 2
Install and run GDS2 on all the PCs on which you intend to use the GDS diagnostic software.
Step 3
Windows OS automatically hides the "programData" folder. To unhide hidden folders, use the Windows Explorer settings.
Navigate to C:\ProgramData\GM\TIS2WebProxy\.dls\.lreg
From that folder, delete the licence file that's there and replace it with the attached infiniteLease.dat file.
The infiniteLease.dat file also works with the new Techline GDS2.
Step 4
Restart the GDS2 application. The Days remaining until the lease expires should change to infinite.
For Techline, connect GDS2 standalone mode.
  1. Go to C:\ProgramData\GM\TLC\TIS2WebProxy\.dls\.lreg
  2. Delete the file that's already in the ".lreg" folder.
  3. Place the infiniteLease.dat file you downloaded into the ".lreg" folder.
  4. Close and reopen the Techline Connect application. The days remaining until the lease expires should change to infinite.
GDS2 Infinite lease file
View full article
  • Replies 27
  • Views 5.4k
  • You can also search around for a VM version of techline and use GDs2 offline, and use the same patched lease to extend the trial period to millions of days!! Like I did, for 100% free. However it need
  • Yes Techline overwrites some files. Just keep a copy of the lease file in a folder on your PC and when Techline overwrites it, copy and past the lease file back to the location.   Techline u
You can also search around for a VM version of techline and use GDs2 offline, and use the same patched lease to extend the trial period to millions of days!! Like I did, for 100% free. However it needs to be a 64x machine, that can support virtual mode 64x. If only we could find offline sps programming.
You never fail to amaze Troy
Will the lease patch get overwritten if you login to techline connect (not standalone mode)? Just confirming how the process works.
Techline uses the same lease file, but Techline store the lease file in a different location.
check these Techline location as I don't fully remember the Techline lease file location.
" C:\ProgramData\GM\TLC\TIS2WebProxy\.dls\.lreg"
"C:\ProgramData\GM\TLC\TIS2WebProxy\.dls\.TUM\.lreg"
Tried figuring this out today but mine looks different.  Not sure what file I'm supposed to replace with the infinitelease.dat file as there is no *.dat file in any of the folders suggested.
Any ideas?
Need help what file do I delete thanks
The lease file works with the new techline gds2.
I’ll look into it soon and update the tutorial with info on how to apply the trick to the new Techline GDS2.
another problem, after installing infinitelease i opened gds2 and it showed the large number of days until expired, this is with tech line standalone mode. i then when on line to my ac delco account and logged in to check if sps still worked and it does, however when i went back to gds2 standalone mode the lease was back to 179 days and all the dignostic packages were erased. i can no longer do any diagnostics in stand alone mode
Hello Troy at the first time i use techline connect after many update from Ac Delco  i receive an error message and even i pay for a vin i can use the program .The program accept my mdi but give me that error after i write the vin .Do you have an idea? thank you
9 minutes ago, nostra said:
Hello Troy at the first time i use techline connect after many update from Ac Delco  i receive an error message and even i pay for a vin i can use the program .The program accept my vci but give me that error after i write the vin .Do you have an idea? thank you
I receive that error before.
To fix mine, I uninstall TLC and all general motors application from my pc control panel. Delete the GM folders, then re-install TLC. It worked fine after doing that.
If we want to use the gsd2 only do we have to pass by the techline or it will start indepedently?
Any ideas?
Did you get it working I have the same as you do?
4 hours ago, duraid M .Saleh said:
hi dear
I need file for radio gmc 2015
I need change used radio plaz
For used satellite radio and HMI 2.5 module, it will remove the theft lock.
  • 4 months later...
Hi troy could you assist me in getting unlimited lease file location i cant find no file to replace it with thanks
Hi, if you’re using techline connect, the location is C:\ProgramData\GM\TLC\TIS2WebProxy\.dls\.lreg
The programData folder is automatically hidden in windows. Use windows explorer settings to unhide hidden folders.
Thanks got it
i placed file in C:\ProgramData\GM\TLC\TIS2WebProxy\.dls\.lreg and delete the old file and i now get lease has expired message.
Does this no longer work or am i doing something wrong?
Hey bro, did you figure this out?
Got it to work.  Tried a few times.  Make sure you change settings for windows to show hidden files.  Be careful to navigate to the correct spot there will be a license file already in there.  Delete it and replace with Troys.  I navigated past the screen that said I didn't have a valid lease, put a vin in and it worked.  Went back out and it shows the gazillion days till expiration.
does this contain only the US models or can be added also other diagnostic package e.g. for EU cars?
Mikluha_Maklay cronkllr Rodrisilva codebuilder Micki Mikkelsen Pasha Brock Johnson Ringtee mattb artur minasyan Emmanuel Koomson Lyubomir Krastanov SCAMMER T_Ivan islamkhan Obada Alrifaee zph666 cf_moreir Diko
