How to get cheap GM GDS2 for eternity.
11 hours ago, BraynV said:
does this contain only the US models or can be added also other diagnostic package e.g. for EU cars?
Works for both Global GDS2 (v22.x) and Opel GDS2 (v100.x) versions.
Diagnostic packages are not license dependent - you can install and use whatever you want (some newer Deliverables do require some certain version of GDS2, though)
  • Replies 27
  • Views 5.4k
  • You can also search around for a VM version of techline and use GDs2 offline, and use the same patched lease to extend the trial period to millions of days!! Like I did, for 100% free. However it need
  • Yes Techline overwrites some files. Just keep a copy of the lease file in a folder on your PC and when Techline overwrites it, copy and past the lease file back to the location.   Techline u
thanks.
once connected to SPS, this solution with the infinite file will discontinue, right?
Looks like it.  I updated and I can no longer get it to work.
Mikluha_Maklay cronkllr Rodrisilva codebuilder Micki Mikkelsen Pasha Brock Johnson Ringtee mattb artur minasyan Emmanuel Koomson Lyubomir Krastanov SCAMMER T_Ivan islamkhan Obada Alrifaee zph666 cf_moreir Diko
