EPS Chevrolet Trailblazer 2 2020 3.6L
Hello! Chevrolet Trailblazer 2 had its electric power steering (EPS) replaced with a different part number, 84494271. Will changing the calibrations from 84579653 (the original EPS) to 84494271 help? The VIN is registered, but error C056E occurs. The EPS needs to be calibrated after updating the calibrations? Thanks.
GCI_Log_84494271.Txt GCI_Log_84579653.Txt
Solved by Troy
  • Views 262
  • Yes, use the SPS setup and configuration to calibrate the EPS.
  • Yes, the type4 file should work.
Okay, thanks! I have the DPS files with the necessary calibrations and a Type 4 file for the EPS configuration.
type4 file EPS Configuration
  • 3 months later...
The problem was solved. I updated the calibrations through the DPS, no adjustments were required, and the power steering worked without errors right away. Thanks everyone.
GCI_Log_After.Txt GCI_Log_Before.Txt
  2. Adelin
  4. GM-Enthusiast
  5. regloops
Mikluha_Maklay E-Ing-X20XEV Galaxie Adelin pupu14 The_CarGuy_2018 Shifty chita_it Alpha jjagel Last_Captain Flash Lyubomir Krastanov nev3r Rizk Suwaidan blocked SergSanich Ramin KaDD markichev
