How to correct checksum after editing GM's calibration files
Whhat option in SPAT do i need to use? its a .bin file and cant find any option to zip that back so its like a original sps cache file
  • Replies 110
  • Views 16.9k
  • Eric Ellison
    Eric Ellison
    Nice info Mr Troy, but if I may offer some advice the windows Calculator has a Programmer mode that easily takes the last four of Big-Endian HEX checksum(highlight all bytes except the first two of .b
  • The way I find the easiest is to set the first two bytes in the file to FF FF, calculate the big-endian 16-bit, take the last 4, i.e. 2F B5, use the Hex Calculator to do FFFF - 2FB5, giving us a resul
  • Mindaugas Cernius
    Mindaugas Cernius
    The checksum calculation can be different for everyone. For example, in BCM Opel using 16-bit Big-Endian, you need to add 8000 to the resulting result to get the correct checksum. We get Buick's check
spat, create a new archive. follow the text in the window and make your own files.
have a HMI file and what i can see its uses big endian, i get 1288 as checksum on this  file, can anyone confirm that?
I get error when i run the archive in dps
84229478USA2.5.bin
84229478USA2.5.bin 565 B · 0 downloads
check this
3 minutes ago, Arbe_gtc said:
i have read that several times and followed the directions how to create the checksum  but i dont think im getting it right, can you check if the cheksum i got 1288 is correct for the file ?
On 10/11/2024 at 4:05 PM, Arbe_gtc said:
use SPAT option in DPS to create the package
the checksum of this  file es A4 5E, read again my message, HMI uses little
When i try little endian i get 5ea3 then +1    5EA4
Hex value:
5ea3 + 1 = 5EA4
Hex value:
5ea3 + 1 = 5EA4
Sorry now i can see that it most swap so A4 first then 5E, right?
you need swap it, yes
Thx will test that tomorrow
Is it possible to get 068B as hex and then with +1 its only 68C  so missing one nummber? or do i use C068?
On 8/30/2024 at 10:23 PM, Mindaugas Cernius said:
Hello colleagues. After calculating the CheckSum I got the result f2, how do I write the first four bytes?
On 8/31/2024 at 12:26 AM, Robi_X said:
00
@Dan79 same with 3 bytes.
so 68C becomes  8C 00  for the hmi file?
123=0123
12=0012
2=0002
Hi tested this on 2.0 hmi to see if its the same and its very simular  but the 3rd bit is almost always wrong , like on the attached file if i ran the checksum i get 5914  but checksum is 5994   , tried on several files and always the 3rd is off like if oem is 4BE6 I GET 4B06   , do you know why this is , it uses little also
23154070.bin
i dont know what is your problem...
if you try to calculate thechecksum on this original file you will get 5914  and not 5994 like it should be , try your self and you will see you will get 1458+1=1459  so 5914  and thats wrong , thats why i wonder why
i got the correct checksum, you can see it in the previous image
please show me the steps as i cant get the correct one at all , im stuiped i know:)
the NOT of 6BA7 i get 1458 then +1 =1459      and thats 5914
I dont know how you get 1458
That i understand ,please try this file and tell me what the cheksum is , i have edited  so the first bits are not correct know, i want to check if we get to same conclusion , if i go trough all the steps to check cheksum (little) i get BB2B for this file.
23648990.bin
23648990.bin 915 B · 0 downloads
this file its the same
sorry here is it , i get BBAB on this one
23154070.bin
yes i get also BBAB
kobrak16 chicking thxx VS VIPER Andy_san Firestars Dog VoltGuru saad_dubai Enterlan bright liang Arbe_gtc Lulu JandJSpeedShop PixelTheKWolf Mikluha_Maklay kosta Pasha Kamilmichu kev789 Encrypted Owner
