How to correct checksum after editing GM's calibration files
Its BB AB, but if the unedited file ful checksum, is 0x80000 the edited file must be 0x80000.  if you correct checksum and the original file have 0x80000 and the edited file have 0x90000, if i remmember, it fails in programming
  • Replies 110
  • Views 17.4k
  • Eric Ellison
    Eric Ellison
    Nice info Mr Troy, but if I may offer some advice the windows Calculator has a Programmer mode that easily takes the last four of Big-Endian HEX checksum(highlight all bytes except the first two of .b
  • The way I find the easiest is to set the first two bytes in the file to FF FF, calculate the big-endian 16-bit, take the last 4, i.e. 2F B5, use the Hex Calculator to do FFFF - 2FB5, giving us a resul
  • Mindaugas Cernius
    Mindaugas Cernius
    The checksum calculation can be different for everyone. For example, in BCM Opel using 16-bit Big-Endian, you need to add 8000 to the resulting result to get the correct checksum. We get Buick's check
Ok thx but if the edit file has correct checksum but shows now as 0x91000  is it possible to fix that ?
something is wrong. the checksum in HMI must end in 0000. share this file
here it is  after edit it i got 15 0E as checksum
23648990.bin
I get 15FE?   (0xA0000)
23648990.bin 968 B · 1 download
this file shared is more lenght than this
23648990.bin
Ok i upload original one and that is 0x80000    and i upload the edit one that i get checksum of 0E15 and 0x91000
23223112.bin 2323112.bin edit.bin
2323112.bin edit_2.bin
   0x90000
Try it
5 minutes ago, Arbe_gtc said:
Can't download it ,are not +contributor.
What did you change ?can you show me?
Was 0E15 correct?
Was 0E15 correct?
1 minute ago, Arbe_gtc said:
Thx I will test that and let you know the results
Mikluha_Maklay thxx Enterlan MaxGood kurld radi Adelin kobrak16 chicking VS VIPER Andy_san Firestars Dog VoltGuru saad_dubai bright liang Arbe_gtc Lulu JandJSpeedShop PixelTheKWolf kosta
