How to update Insignia/Buick Regal 2014 IPC firmware to 2017 with GM DPS
does somebody have a comparison of 2014 vs this 2017 version? What is different there?
In the download, there are 3 folders, but no instructions, what & how to proceed. Can anybody advice? Thanks
  • Replies 40
  • Views 5.9k
  • Yep, the IPC now has a none 2014 Operations software version so SPS won't give files.  I don't have the 2014 firmware as I never thought of saving it, The 2014 firmware shouldn't be as issue to g
  • hi Troy thanks for file, working fine try sharing with my original ipc 8'' firmware from 2015, maybe somebody needed IPC 2015 8'' Firmware 84137905.zip
  • Camaro and Corvette firmware in Insignia A cluster
newer software and functions
do you know the steps, how to do it? in the absence of Readme file, I am not sure, how to proceed.
Is really a SD card needed or it will work also with USB stick?
You need an hmi 2/2.5 system to upgrade. Plug the USB with the upgrade files onto the car, and in the screen you show a update available
thank you. that is what I needed...
On 2/19/2023 at 12:14 PM, Ernestas said:
That looks smart as fu*k.
Would you be able to share them firmware files?
have you tested it?
Is there any recommended size of the USB flash drive?
256MB would be enough?
I've got various 4GB and 8GB but that's because I took a snapshot.  Is it 256MB or 256GB?  256MB can barely hold a Sierra game today :).  You need at least 8GB.
Use Sandisk Cruze Blade 64GB
Works fine for upgrades
Thank you for your prompt answer
done the update. All good, but with one observation: When Cruise Control is active, the icon is not green anymore, but only white coloured.
On 7/24/2021 at 7:23 PM, Troy said:
Don’t know man. I updated a 2014 and a 2016 IPC with those files with no issue.
Can you use sps to get the original firmware.
to get back to original version of IPC, shall SPAT be used with original cal from SPS? (and to load it with DPS)
The Cruise Icon is for ACC dose you car have this?
yes, the icon is there - visible, but remains white, even after activating the ACC. White should be, when ACC is in standby, showing the last used ACC speed. When you activate the ACC (to hold you at the selected speed), normally, it should be green, shouldn't it?
and yes, my car has it
@BullMech you have to find calibrations with ACC for this firmware
Savip_ marcel_hack_guy Opelfan jingwei Troll Deryck Enterlan notovi Lyubomir Krastanov Adelin Batesz Mantas Jucius stensin slpshtbms OP kobrak16 tan tan exc11 Artur a b Opelinsignia1985
