How to update Insignia/Buick Regal 2014 IPC firmware to 2017 with GM DPS
The firmware files.
  • Replies 40
  • Views 5.9k
  • Yep, the IPC now has a none 2014 Operations software version so SPS won't give files.  I don't have the 2014 firmware as I never thought of saving it, The 2014 firmware shouldn't be as issue to g
  • hi Troy thanks for file, working fine try sharing with my original ipc 8'' firmware from 2015, maybe somebody needed IPC 2015 8'' Firmware 84137905.zip
  • Camaro and Corvette firmware in Insignia A cluster
5 hours ago, Kovacs Nora said:
Thanks! But this page flipping album format is very weird, it is like a Tesco catalog. ?
The filp book backend makes it very easy for me to create tutorials and it has some very nice features that a PDF creator doesn't have.
On the plus side, I need the web traffic. Viewers have to visit the page to read it.?
A workaround is to turn the sound off and take some screenshots of the pages.
Happy So Excited GIF by TikTok
Keep it up wizard
Hi Troy
I'm just done that upgrade 8" cluster from 2015, but is something wrong, I'm not sure You have same symptoms after that,  clock working OK but lost on settings completely display Theme option to chose sport or touring and info page to activate and deactivate options, that happen after when firmware update, after install calibration, but still same. Do you know how to fixed maybe? THANKS
Hi all
Any can help me to getting cluster firmware from my oryginal vin please ?
W0LGS8EMXF1041644
On 7/23/2021 at 7:38 PM, M Ch said:
Hi Troy
What type car is it and what year was the IPC from?
Hi
Insignia A 2015, yes I do firmware,  cali, and my PRO with my vin and VXR code
All completed successfully
Hi sorry my insignua 2014, cluster from insignia 2015
Don’t know man. I updated a 2014 and a 2016 IPC with those files with no issue.
Can you use sps to get the original firmware.
Hi
Thanks Troy
I'm just managed to downgrade firmware and all option comes back
If someone need that firmware file let me know.
Still one thing I need to do, because my car don't have tyre monitor system, and I not sure how to switch that option off, any suggest please?
I try switch off that two option, but still nothing
Hi and thanks for sugestie, but my DTC is off already
I thing need to switch off menu, anyone know with option is for TPMS
Hi Troy
Do You have your oryginal calibration from IPC 2014, because I can't install and download my oryginal from this cluster, because already install your from 2016, and oryginal is from 2015 and SPS coming error E4419 see picture,  can you share the file please, and I try with DPS
I don't have the 2014 firmware as I never thought of saving it, The 2014 firmware shouldn't be as issue to get via sps.
Here is the 2014 IPC DPS calibration package.
Check your Vin in
TIS2WEB.SERVICE.GM.COM
 and see if your VIN calibrations files matches this one.
hi Troy
  • 9 months later...
Hi!
My Insignia is a 2014 model, but it has HMI 2.0 module. I see from the tutorial that you have a 2.5 HMI (single USB port). WOuld this procedure work with the 2.0?
7 hours ago, RaduB said:
Hi!
Hi, I'm not sure. I update my HMI 2.0 to 2.5. For the apple CarPlay to work I had to change the USB port to a single port.
  • 8 months later...
Hi Troy, in the documentation the video is not available what for editing xml file. Do you still have it somewhere?
  I have a problem writing them correctly for my vehicle. It would be cool if you could help with that.
There are a few functions that are no longer that and I don't have an AWD either. thx
VIN: W0LGT8EM0E1103130
IMG_20230218_210918_666.thumb.jpg.a276b3a9623ec6057789e22975fd0e2d.jpgIMG_20230218_235556.thumb.jpg.ba4f8a42482b60eed3498bb6d14918f5.jpg
That looks smart as fu*k.
Would you be able to share them firmware files?
I don't know the real compatibility of the firmware, and the consequences of a failed update. And the possibility of bricking the instrument panel. If someone wants to test under his responsibility, you can easily search for the vin of a camaro or a corvette in google for example corvette 2015 vin
Savip_ marcel_hack_guy Opelfan jingwei Troll Deryck Enterlan notovi Lyubomir Krastanov Adelin Batesz Mantas Jucius stensin slpshtbms OP kobrak16 tan tan exc11 Artur a b Opelinsignia1985
