Chevrolet Impala Automatic Head lamp won't off at day time
Solved by JBL_1989
4 hours ago, TunnerXP said:
Thanks for your reply LLCasaol my techline connect not working looking for calibration files for VIN's if you can arrange the files it will be nice
you need to program your BCM once and save file, BCM auto exterior calibration was #6, 23217111, change it by 23217112 from 2017image.png.3c13476f95d110f608d48c6836b3c072.png
  • Replies 35
  • Views 1.4k
  • Last_Captain
    Last_Captain
    Share GDS2 REPORT of vehicle to get clear picture of your issue
  • GM-Enthusiast
    GM-Enthusiast
    Daytime Running Lamps (DRL) The daytime running lamps (DRL) will illuminate continuously when the following conditions are met: The ignition is in the RUN or CRANK position
  • GM-Enthusiast
    GM-Enthusiast
    change bcm calibration,, swap AUTO lighting calibration from lower year
Thanks alot bro really appreciated my techline connect working now i try to get files for both VIn and then i will swap number 6 file and then i update this post..thanks again
HI my zip is ready according to LLCasaol  waiting for car to come in my shop so i will program the zip i attached the orignal files which i got from sps maybe someone need it later.. thanks
IMPALA_BCM_2018_UNZIP.zip
hi LLCasaol after programmed archive its strange now at day time low head lamps on at night it will off 🙂 so i returned the orignal program ... its mean 2017 file 23217112 will not work.. need to find something other..
Could you adjust CAL 06 offset 0x377, 0x37A to 0x00?
hi thanks for reply CAL#6 orignal one 23217111 or from 2017 one 23217112?
I mean with original CAL 06 (23217111).
ok please check the picture these are need to make 0x00 or i am wrong and what about checksum i need to correct checksum after that? because i don't know how to correct checksum ... thanks youScreenshot_18.png
file modified and checksum corrected
06_23217111_mod.bin
06_23217111_mod.bin
thank you so much bro i check this and will update you..
UPDATE after followed JBL_1989 MY PROBLEM IS SOLVED NOW LOW HEADLAMPS ONLY WORKS AT NIGHT THANK YOU SO MUCH DEAR JBL_1989😍
Savip_ said4275 Tham veetdoc Enterlan mohamed montaser SnugMyg thxx BadBoiDJ TunnerXP Morooo
