How to create GM DPS archive file from SPS cache files for HMI module
You can learn how to obtain calibration files from GM SPS service by enrolling in the course below, which is necessary for creating the DPS archive file.
You can learn how to manually create the DPS archive file used to program a GM vehicle model by enrolling in the course below, which is necessary for creating the DPS archive file.
You can learn how to manually create the DPS Type4 file used to program Setup And Configuration settings in a GM vehicle model by enrolling in the course below.
As of 2022, there is no longer a need to create the DPS archive file manually. Instead, you can use the GM DPS Archive Creator Tool, purchased at the following web link below. This tool allows you to automatically create the DPS archive files and DPS Type4 Files, saving you time and effort.
View full article
  • Troy pinned and unpinned this topic
  • Replies 81
  • Views 25.5k
  • Opel_driver
    Opel_driver
    This is truly great. Thank you.
  • You are COOL!! Tnx very much
  • ? @loom.   I created a bench setup recently.  It took me some weeks to sort it. It was pain to get the HMI to speak on the HS-can line.  In the end I learnt some stuff about it. For the HMI,
Hey Troy, can you please share an utility file and one calibration file? I didn't manage to solve that issue that the archive created is not a GMLAN archive. thanks
thanks Troy. It's clear for me now that my files from sps folder are somehow encrypted. I'm using GT32 offline.
2 hours ago, Abdullah Anwar said:
Great work
Is there anyway that i can extract maps from hmi module ? Or add other language?
It should be possible but I don't know how to do it yet.
Can you try with online sps?
no, I don't have online access. Tried something right now and guess what....managed to unpack the files from sps folder with 7zip. I can see some plain text in files so now they are good, build a new archive and I'm not getting that message anymore. So I'm on the right track, I'll start to build the bench loom now. I hope to succeed at the end.
For the HMI, all the units must be on the MOST line ie, IPC, CD drive, HMI, Radio, and BCM and/or the MOST loop must be complete.
And most important the BCM is the one who gives the orders if the HMI should speak or not via the 'Serial Data Communication Enable' wire.
I'm using an old xbox360 power supply to power the modules.
Bofore
5 minutes ago, Kovacs Nora said:
Hello Troy! Big thanks for your work! Can you post this tutorial in a normal html/pdf? This book format is very weird for us! Thanks!
Unfortunately it wasn't made in a PDF format and I can't convert it.
You could try a different web browser like Firefox and Chrome.
It will not be my first one ?. I only need to connect ABS pump (which I want to... let's say "hack"), BCM and ECM. Probably I'll do a complete one  with IPC, light switch, as I have more mods in mind to do.
hi Troy
Great work THANKS
i just build few file already radio, bcm, hmi and cluster calibration
do you figure out where touchpad located?
i have my 2,5 install on my car with all extra, done by professionals (see picture) and calibration is similar like your file,
I think touchpad sit in Display interface Calibration file.
what you think?
On 6/12/2021 at 10:43 PM, M Ch said:
hi Troy
Great work THANKS
what you think?44117474_2021-06-1212_50_52.thumb.jpg.d53a8f36bb6d9b6c1287e79a79dee58c.jpg44117474_2021-06-1212_50_52.thumb.jpg.d53a8f36bb6d9b6c1287e79a79dee58c.jpg
Good stuff?.
I remember seeing the touchpad cali in either the HMI or the radio. I'll check later.
@troy i like your setup!, you don't need to have all the devices in the MOST for it to work, but the loop should be closed, the only 2 basic modules for the system are the HMI and the tuner (radio module) and the display of course.
Thanks Troy I had a 2018 silverado I was trying to get a arps file to work. It just didnt work. Then I unzipped with 7zip and built a arps file with the bin files and that worked. But it did not let me change the VIN. I need to play around with that yet.  I did try the SET_MEC_TO ZERO and that let me write a new vin over it with SPS so I may just have to use that option
Hi. I tried to take the bin files from SPSCache folder but there was no files during the SPS procedure. I used online TIS2Web and there was a new sw available for selected module and I did the reprogramming but no files appeared in the SPS Cache folder. Any ideas why?
Did you look in the spsDebug File. They are stored in they some times. I set my sps file to sort by date and then when you program something all the new file come to the top. Good luck
Has anyone found the calibration files in SPS2 yet? I was just forced to install Techline Connect.
There is a SPS Cache directory at C:\ProgramData\GM\TDM\SPS Cache but the calibrations files never appear.
Edited by bdiveley
Yep, same here, Tech line doesn't save the files to cache folder like the older sps client does.
Hopefully there's a work around, as I read GM will be retiring the old sps client soon.
I mighty be talking shit, but my techline saves bin calibration files in same location user/sps/spsCache/spscacheinternal... im just having issues with getting hmi ipc files as it throws this (see pictures)
And when I'm trying to copy lets say XMLFile It doesn't let me do that,as it's being used by java the moment to cancel programing it disappear. Is there a way to force copy a file?
Edited by Ernestas Dikinis
Oh yes. As I use TIS2Web online SPS then this stores the bin files into SPSDebug folder. But there is again a problem - the bin files appear not during when the calibration numbers are being dispayed (like said in the Troys instruction page 8-9) but the files appear after I press the NEXT and the reprogramming procedure starts. See the screenshots. Troy did you use GLobalTis to get the bin files already during the calibration number page?
Would like to get the bin files before starting the reprogramming event because once the reprogramming starts and finishes then OPEL is charging money for it. I wonder what happens to a module if I pull out the OBD connector right before the reprogramming progress bar starts to move? 🙂
jarrod early kitsaras Scammer Esteban Bogarin Adelin ruben casique collider jjagel Robby Schrimsher Hussainaaaa AMJar Mikluha_Maklay peter Christos Tsirdanis Enterlan AZCKNCLLC raku_og Pasha SIGIT W Kpeezy hussam alwan
