How to create GM DPS archive file from SPS cache files for HMI module
51 minutes ago, Troy said:
You get that error "this is not a valid GMLAN achieve" because the files are still compressed.
Use 7zip to uncompress the 3 files then use those files to create the DPS archive. Always uncompress whatever files sps gives you before you create the archive, it doesn't matter if it's a .file .bin.
Here are the uncompress files, use them to create the archive.
Thank you Troy. I appreciate it:)
  • Replies 81
  • Views 26k
  • Opel_driver
    Opel_driver
    This is truly great. Thank you.
  • You are COOL!! Tnx very much
  • ? @loom.   I created a bench setup recently.  It took me some weeks to sort it. It was pain to get the HMI to speak on the HS-can line.  In the end I learnt some stuff about it. For the HMI,
Hello 🙂
Do you think it is possible to make Cadillac CTS panel working with EU Opel silverbox? (No, it does not work because radio controls are different in Cadillac than in Opel). Could You help me with that? I have some files but don't know what should i change :(.
I have LINBus frames sheet for both silverboxes and i thing the problem is Cadillac panel calibrations or Opel silverbox calibrations (controlls calibartion).
Screen was made using US Cadillac silverbox. Using Opel silverbox illumination is gone and screen backlight off. I am not able to do anything using that panel.
Files containing silverbox callibrations.
1G6AU5S89E0163569.7z W0LBF6EH9HG167435.7z
  • 7 months later...
On 12/4/2021 at 1:36 AM, Alejandro Borja said:
But i need to know how to use DPS to change the vin ???
Please help me !!
THANKS
Hi !
I have the same questions, HOW change VIN with DPS ?
3 minutes ago, Cristian Mignason said:
Hi !
You need special DPS file which can be used with DPS to change the vin in the HMI or other modules. By itself DPS cannot change vin.
Europe HMI VIN change.
USA HMI vin change.
I never see BIN files from SPS2. They dont come like the tutorial shows. The files that SPS leaves in the folder are with NO extension. If I use 7Zip on those files with no extension, it actually CREATES the BIN files. This may be the reason I cant complete programming and get error messages. Has anyone else seen this problem? Am I pulling files from the wrong folder? I get the files from spscacheinternal or Type4. Troy, you out there? Could really use your help.
Files are from spscacheinternal. Unzip it regardless if .bin extension or not.
  • 6 months later...
I have the same problem I think. The spscache folder have files without extension. I can't unzip them. How shoud I do this ?
Hlk Sadro Hussam cleison PaulyVoltMan Hussainaaaa dgjtools jarrod early kitsaras Scammer Esteban Bogarin Adelin ruben casique collider jjagel Robby Schrimsher AMJar Mikluha_Maklay peter Christos Tsirdanis Enterlan AZCKNCLLC
