How to activate remote start and change VIN number in GM's instrument cluster BMC
  • Replies 73
  • Views 13.8k
  • I have test my Software and now i can do all Cars for 2010-2022 with remote Start ;D
  • I figured out the BCM part, but it seems the ECU calibrations files also needs to be modified for activating remote start, which I don't know yet.
  • Hello Guys for Insignia i can activate Remote Start Finally. On Petrol you have to Change 1 DID
On 08.08.2022 at 18:18, Sergey said:
Добрый день.
Никто не разобрался какие калибровки отвечают за автозапуск? Поменял 2. Система 9. Управление гидропередачей 20. Регулировка вентиляции и кондиционирования у меня машина перестала заводиться, хотя ошибок не было. Менял отдельно 9. Управление силовой передачей, но запуск не появился. Заменить все калибровки не получится, как я писал выше, автомобили-доноры не имеют точной конфигурации систем.
Good afternoon. Did you manage to remote start opel astra j?
YES
22 hours ago, WSOpel said:
YES
Which blocks need to be updated? BCM?
Can you tell me what calibration needs to be added?
@WSOpel Can you activate it in Opel Insignia 2015 A20DTH (EDC17)?
  • 6 months later...
@WSOpel
What needs to be edited and in which blocks?
W0LGT8GM5C1045901 the latest available calibrations have been installed.
Hello, which tool need i to open the File from the ECU?
HPTuner, Trasdata, Foxflash, EFILive, TunerCat, etc
Hello, thanks a lot i will check it. Can i also other GM Calibrations open with this tools?
Hey guys, what calibration flie (#1-20 bin) in the BCM is responsible for the remote start?
Hi, What key with remote start works on a astra k or insignia b?
It should be in Cal #5 I think.
Found in calibration #2
Post
Post
Ah so just the timer is in #5 then.  Or I'm thinking of the incorrect year BCM's
Can you say what bytes must be changed?
did you manage to find out?
I test with original holden rhen remote start works. But i don't know waht i must changed in the engine ecu. Did you know it and dcan say it?
you need to collect your DPS archive for the ECU and BCM and flash the car.
In the BCM it is necessary to change calibration 5, in the ECU I don’t know.
Ah ok, that is right in BCM the File 5 only the ECM i don´t know what right is. With all files from the Holden Astra it works.
What's stopping you from leaving it as is?
Haha no the adaptive cruise control not work it is not inside the holden file
Hello.
When you say 1 DID, do you mean 1 calibration DPS or 1 DID in XML, for example DID0027?
1 DID for example DID0027?
Hi all.
Help me out guys.
I found over 50 VIN numbers for Buick Enroce that came with BTV from the factory.
I checked all these numbers manually and wrote down the calibration numbers.
I made myself 12 different DPS archives, all of them successfully loaded into my car, but I still did not have a remote start menu in my radio.
The radio just now has a menu for turning on heated seats with remote start, but there is no remote start itself.
What am I doing wrong?
Hi you need engine file and bcm file. Bcm number 5 and engine Nr. 1 or two. Search a car with same rpo and use this engine file
Daniil_Ast Vericu MaxGood Adelin maczoka chicking hassan77h Camelot Troll Deryck Alpha Obada Alrifaee crystyxcw Enterlan Diesel Mikluha_Maklay HOME notovi Teklock OpelGuy LIWA
