How to activate remote start and change VIN number in GM's instrument cluster BMC
30 minutes ago, Hero Tran said:
Hi Troy, Have you determined BCM Calibration .bin (With Remote Start) yet?
Hi, no I couldn't figure out how to activate it. Next summer I'll try some more.
  • 6 months later...
  • Replies 73
  • Views 13.2k
  • I have test my Software and now i can do all Cars for 2010-2022 with remote Start ;D
  • I figured out the BCM part, but it seems the ECU calibrations files also needs to be modified for activating remote start, which I don't know yet.
  • Hello Guys for Insignia i can activate Remote Start Finally. On Petrol you have to Change 1 DID
Now Summer. It's time 🙂
Hi @JBL_1989, In Korea, there is any Chevrolet Cruze applying remote control to start the engine, isn't it?
Hi @Hero Tran, yes. it is. remote vehicle start disabled in factory but 3rd party modders are providing remote vehicle start on Chevrolet Cruze (J300) and all new cruze.
Good afternoon.
I've also been trying to activate remote start on my OPEL ASTRA J for a long time. The closest relative is the Buick Verano. When replacing the full BCM software, the AFL module K26 lights stop working. I'm trying to record the low beam calibration from my vin. But all the time I fail in programming on the last percent. Tell me what I'm doing wrong?
Dps programs to 99% that means the module was programmed fine. I don’t know why you got that error.
No one will know the answers when swapping BCM calibration files. You have to try different files until you get it working.
@Sergey How about modify compatibility flag located at offset 0x00C, 0x00D?
A valid compatibility flag for your BCM is... (Calibration 06) 0x01, 0x18 (based on your BCM main program in archive file you provided)
I hope this helps you.
P. S.: I'm looking for BCM calibration file from VIN Holden Malibu 2014MY CDX - KL3GA69U9EB065370 (both &T3X / -T3X) anybody please help me to obtain calibration file 😄
Good afternoon.
No one figured out which calibrations are responsible for autorun? I changed 2. System 9. Power transmission control 20. HVAC adjustment my car stopped starting, although there were no errors. Changed separately 9. Power transmission control, but the launch did not appear. It will not be possible to replace all calibrations, as I wrote above, donor cars do not have the exact configuration of the systems.
Am 26.07.2022 um 19:09 Uhr sagte Sergey:
Ich erhalte diesen Fehler, wenn ich versuche, die Lichtkalibrierungsdatei zu ändern. Wenn alle Dateien nativ sind, gibt es keine Fehler und der Block startet vollständig ohne Licht.
This is because your calibration does not match the OS you want to install.
Kann ich so auch das BCM clonen?
we were having similar issue over here in the states adding remote start, there is a parameter in the ecm you have to edit for remote start run time
What program are you using to modify the ecu? I'm trying to do the same to an 2015 Chevrolet Malibu LS. I had tried to do it through tds but it was asking for one very small file when I tried last year. I'm now delving into trying to get this enabled since it only needs an code to get it enabled with no extra parts. I had been away from all this programming for the past two years. I'm trying to play catch up now.
Is this for Insignia-A 2015?
For all Insignia B and some Insignia A ( will try more Insignia A )
On 8/8/2022 at 4:18 PM, Sergey said:
Good afternoon.
Any luck Sergey? Also wanted to activate it at Astra J.
  • Popular Post
On 01/02/2023 at 11:55, jeremy mccain said:
Biz masofadan ishga tushirishni qo'shadigan shtatlarda shunga o'xshash muammoga duch keldik, ecmda masofadan ishga tushirish vaqtini tahrirlashingiz kerak bo'lgan parametr mavjud
Ushbi Dasturni Menga Yubora olasizmi Raxmad
any gearbox?
For diesel You have to set one DID to 1
insignia a a20dtr automatic possibel?
  • 4 months later...
I have an Insignia A 2015 1.6T petrol vehicle. I want to do it too. How can we do?
Adelin chicking hassan77h Camelot Troll Deryck Alpha Obada Alrifaee crystyxcw Enterlan Diesel Mikluha_Maklay HOME notovi Teklock OpelGuy LIWA lsxtuner tobiasp greaseman lvulcan
