@Arbe_gtcthanks buddy
Also I do too( the vin look up
If you want I can share with you our inventory vehicle VIN most of them US imported
Do let me know if I can the favour back
  • Replies 890
  • Views 71.1k
Can someone please post the ECM Utility file for this VIN# please
1GNEVJKW7JJ102445
I just need the utility file.
Guys I need calibration for bcm 13518372 VIN: 1G1FE1R78J0162132
Regards
  • Popular Post
Regards
BCM.7z
On 9/11/2026 at 8:49 AM, jorgecostacv said:
Hi anyone can help me with ecu - bcm - immo for 3GNAXSEV6KS632567
Any to help me???
  • Popular Post
Hello, looking for RADIO calibration files for a NA import.
(RPO UUM/U4H) Navigation radio with USB
1 22822471 New software to address OnStar loss of audio condition when vehicle is restarted during a handsfree call session.
3 25986881 Europe
4 25986852 Only for use with UQS speakers.
5 25986873 Equalizer
6 25986823 For Buick and Chevrolet only.
here my brother
5GALVCED3AJ179031_A11.zip
6 hours ago, hassan77h said:
thanks for your file can you send me the ecu calibration too??
the file you sent is bcm calibration or is type4
On 9/14/2026 at 8:12 PM, pupu14 said:
@geku Here you go..
P.S. you will need to create a BuildRecord.bld file with RPO codes for your VIN for K20 ECU setup - I do not have access to GM Korea database...
K9 BCM bin.zip K9 BCM setup.zip K20 ECM bin.zip K20 ECM setup.zip K71 TCM bin.zip K71 TCM setup.zip
Bro here’s the rpo code could you please help me with the files
RPO CODES.pdf
Hey, thanks, but I already have the list and did programming. Also, I'm not a professional here, started learning year or something ago, so I would not take responsibility of someones car. Also I do not know your situation, but from safe actions (reads, no writes yet) I would do next:
0. Read the basics - how OBDII works - ISO14229, SPS Interpreter, GMW3110 and DPS manual - all pdfs can be found on Internet. It will help you a lot later.
1. Create list of parts of affected modules by VIN - to have what was intended there by GM originally
2. Create list of parts currently flashed into the car, compare, investigate - if you did (0) with this knowledge you can understand what's going on in utility files
3. Create backups of all flash, eeprom, even RAM (can have parts of flash for example) etc you can get access to - not easy, will require custom development
4. Get files from (1) and try to get files from (2) - if you have backups from (3) use them
5. Compare 1, 2, 3 investigate a lot - here you probably can have some conclusions and plan further actions
Seems like -T83 was a mistake, even though not listed for the original VIN, soo can I ask for a favor one more time please:
VIN: KLAJA69ED9K132666
binaries and setup for BCM with &T83 (it will have 95962433 instead of 95962434 in bins)
and also Immo learn
many thanks in advance!
On 8/14/2026 at 11:00 PM, Arbe_gtc said:
@geku You can use this Immo learn - already prepared for DPS by @Arbe_gtc
  4. uglyoldbastard
  5. pupu14
    +pupu14
Mikluha_Maklay hassan77h regloops aaronprg Daniil_Ast bondarrenko KiT71 OP pupu14 tobiasp blocked BLKATSG dmytrofan geku dfyznu Alpha jwinters GM-Enthusiast Arbe_gtc Cleberson Santos
