2 hours ago, Pavel said:
Hi, I need the blind spot system files for a 2018 Opel Insignia (B218). W0VZT8GF8K1005327
84033305
39170368
SPS_W0VZT8GF8K1005327_repack.zip
  • Replies 827
  • Views 67.5k
Hi just need bcm calabration files for this vin please W0LPF2EJ6CG064967
give me part number
@Adelin  part number of bcm is
13583956 and the vin is deffo
W0LPF2EJ6CG064967 thank
@Adelin I’ll test it and get back to you.
Thanks so much for your support!
4 hours ago, turbomtor said:
hi everyone
W0LGT57M591097200 need A11 cal files
thank u so much
There are two different sets of calibrations available depending on your hardware number,
I picked up both versions.
Version A for hw numbers: 13300796, 13308129, 13321589, 13326456
Version B for hw numbers: 13326032, 13328731, 13337252
Greetings,
Toby
W0LGT57M591097200_A11_A.zip W0LGT57M591097200_A11_B.zip
17 hours ago, Adelin said:
Thanks, friend. This is probably not the right block! B218L dead zone block.There should be two files there.
Saw now. Sorry, my archive program bugged. Yes should be two files
Check this one.
hi all i need power steering control module files (PSCM) For this VIN KL1ZA5CS2KB115096 thank you
hi friend
Since this is a Holden or Chevrolet Korea vehicle, SPS does not support it.
If you can send me the SPS Calibration Info as a TXT file, I can check the calibration files I have for you and see if anything matches.
Unfortunately, I haven't found anyone yet who can provide calibration files for Holden or Chevrolet Korea vehicles.
best regards
24 minutes ago, hassan77h said:
hi friend
best regards
Brother, I just checked and unfortunately I don't have it. But I’ll ask my friends. Maybe someone on the site can help us with it as well, brother.
Solving this cold case:
Greetings
Toby
W0LPF2EJ6CG064967_BCM.zip
1 hour ago, TunnerXP said:
need CC/CB
2 minutes ago, blocked said:
need CC/CB
Thanks friend for your interest the car is no longer with me when it will come again i can post what info required
It's always the best practice to take a full DTC / ID log with GDS2 or run VCAP with DPS to have the full information on vehicle's control modules and pending trouble codes - in case anything arise later down the line.. 👌
At least that is my approach.
Greetings
Toby
thank you. For some reason, i can't get any files for Astra J
@Adelin Can you try to get A12 Calibrations for W0LJD7D89GB584946?
$CB 13483128
$CC 13484339
RPO UHR
Thank you very much...
image.pngcc and cb incorret , you can check it brother again
@hassan77h
Try with this setup.
Sometimes SPS2 expects CC, and sometimes CB part number.. 😁
yes my brother ı will check same error
I need files for a Corsa E (VIN: W0L0XEP68H4246204) to activate the reversing camera.
JBL_1989 GMcars Shifty blocked mechanix pupu14 Enterlan E-Ing-X20XEV alatka asd WhiteAndBlue Cleberson Santos Arbe_gtc hassan77h CapriceV regloops OP Jasper KiT71 Lyubomir Krastanov tobiasp
