Learn how to activate features in the GM IPC Instrument Cluster using the GM DPS Tool
In this course, you will learn to manually activate or deactivate parameters/options in the IPC using the GM DPS tool.
Click the web link below to enrol in the course.
Things you will learn
Change the VIN in supported modules.
Add or remove RPO codes using the GM DPS tool.
Activate the Speed Limit icon from the Sat-Nav Map.
Deactivate error DTC, such as the Service messages displayed on the IPC screen by faulty Blind Spot side detection system modules.
Activate or deactivate the IPC Pocket Gauges.
Activate the IPC Turbo Boost PSI Pocket Gauge.
Activate the performance menus.
Course preview. A fully detailed online interactive course system, including a tutorial video.
View full article
  • 11 months later...
  • Replies 23
  • Views 2.9k
  • I have a 2012 Cruze that has a salvage title and GM wont help me activate the cruise control. Can it be activated by changing the rpo code the the ICP?
  • No, you will most likely need to program at least the BCM and possibly the ECM and maybe the IPC. You need to find a 2012 Cruze that is built almost exactly like yours except with cruise control and s
  • Hi, is the 2024 GMC CANYON a GM Global-B?
You need to find a 2012 Cruze that is built almost exactly like yours except with cruise control and start comparing the calibration files.
  • 10 months later...
4 hours ago, Manny said:
Does this work for Global B?
Hi, no, Global-A only.
1 hour ago, Emu_Man said:
Is there any progress being made for Global B?
Not at the moment.
Opel Insignia 2013, i need to disable "Side Detection System".
Except DPS and this course, is there need to have access to SPS?
Configurate with correct XML.
1 hour ago, Duba said:
Will i learn with this course how to deactivate/disable tpms opel corsa e for example
Hi, no. tpms deactivation requires bcm calibration file modification.
Is there any particular information or guidelines offered FOR the modification of the Brake Telltale to display the word BRAKE instead of the metric sign ON 2024 GMC CANYON , OR THIS COURSE CAN HELP TO DO THAT THRU DPS
That telltile sign i want to change to word brake
This truck is Canadian production with metric unit , that is why come with telltile sign , so Im looking the way to change to word "BRAKE "
It’s not possible with Dps at the moment.
Canada models uses the same park brake icon as Europe. In global A, Calibrarions of speedometer change this
ask
dt_precision
Edited by blocked
Hi can we change IPC from mph to kph for corvette c7 same like GCC VERSION ?
Possible to do, I've done few of them already.
"Hi can we change IPC from mph to kph for corvette c7 same like GCC VERSION ?"
It should be changed in IPC menu settings
I mean not the system in menu i am talking about 360kmph physical gauge same as canadian cluster ?
  • 3 months later...
Hi , how would this work for European cars that depends on Stellantis service box access (impossible for private access)
  4. Arbe_gtc
  5. Last_Captain
    +Last_Captain
codebuilder Mindaugas Cernius MAKSIM SHAMEDZKA Emad_ali Camelot Arbe_gtc hassan77h BLKATSG blocked Truhnder Gekko jwinters wlcshop Deathcracked Alpha jjagel zzoom Ss Ss Lightbrew Savip_
