Automatic Heated/Cooled Seats
Solved by Robi_X
@ ARBE_gtc
You have HVAC module facelift and calibrations from Astra K 2021 AGR + QuickHeat ? Which Engine?
  • Replies 64
  • Views 4.9k
  • BCM calibrations alters the radio menus, yes
  • @Robi_X     HVAC module facelift and calibrations from Astra K 2021 AGR + QuickHeat. As I still have to install the AGR seats, and change the navi900 intellilink to the Info3 s
  • Looks like it work on Pre Facelift Astra like it should.😄 Current tested Car's: 2016 1.4 Petrol  2017 1.6 Petrol   Also is now the HVAC Menu working (after HMI enable)
6 hours ago, tobiasp said:
@ ARBE_gtc
i have, 2020, AGR + QH
LIH, 1.2 Turbo Gasoline
Is there a chance to cahnce the Engine on this File?
So my statement to the ongoing project.
1. The 202x file are compatible with Module 2016 and up.
2. The 202x files correctly dose not work with the AC System in therms of cool air. (Correctly on to it getting fixed)
3. Most of the important bytes i was able to pindown
->now i try to pindown the solarsensor bytes
Very much Thanks to @Opelinsignia1985and @Arbe_gtc for the help getting it so far.
This is a bit crazy, there are different frames with the same extras that use another 03 calibration. It seems that 01 and 02 never change. for my20 onwards model (only 02 for LHD or RHD)
2016 1.4 Petrol
2017 1.6 Petrol
If anyone wants to test it, they can ask me.
It is indeed a very interesting project, let's see if we can discover some interesting stuff on Insignia A 2014!
So i got Auto Cooled Seats now working on 2016 Cal's.
But not sure if it works because of current outside Temps.
Dose anyone have Insignia B 2018 HVAC file (CJ2, IO6, (C32))?
remove the temperature sensor. and should get a -40º
Dose it not get heating On instead of cooling?
Outside is like 10°C
I try heating to outside temp sensor to 36° but did not turn on buuuuut the inside cabin sensors are still cold so testing now is tricky
Insignia_B_HVAC_CJ2_C32_IO6_RHD.rar
So i need some help.
Dose someone drive a 2020 up Model Astra K(CJ2) and Drive in a Region with current temp's from 8 -11°C?
After some Testing i found that the Blower Motor works harder/stronger with the FL Software on 2016 Hardware.
Now i need to know if its general(normal) that the 2020 models have a other fan curve or the Hack Software dose some wired things.
GDS2 data Log is needed.
Settings:
-All Auto
-Inside Temp 22°C
-Blower Motor setting set to Medium
-Auto Demist setting On
2016 1.4 Petrol
2017 1.6 Petrol
Heten, I'll test these files in my car. I have a modified HVAC with a climate menu, even one more function than in the picture, but I don't have the seat functions. I'll check the AGR settings myself because they weren't standard.
After many weeks of struggling, I managed to turn on all the functions. I probably had them before, but I couldn't get to the "Car" position on the dashboard and couldn't see them, or one of the heated windows and mirrors buttons was malfunctioning. Now it's time to test them in the car. Thank you to everyone who suggested something, guided me, or got me thinking differently.
Hi, who can you get the quality sensor? Or whixh car have this?
M Ch chrissmara Adelin chicking Thamer Mo WSOpel tobiasp John Stevens exc11 Enterlan Robi_X pupu14 bekatsilosani Arbe_gtc bondarrenko crakavelli uglyoldbastard JBL_1989 Opelinsignia1985 codebuilder
