Calibration ipc cruze
- - - show when VIN don’t match. Pin doesn’t play role to display mileage. I see VIN is edited, may be by hand. So there is posibility fo be made error and speedo not function correctly
yes. My update VIN by hand using tool CH341A
  • Replies 52
  • Views 3.9k
  • E-Ing-X20XEV
    E-Ing-X20XEV
    Hey, regarding the autowipers... Have you tried to enable the indicator via 0xA6 Byte 1-Bit 0 configuration DID?   0xA6,0xE6,0x8A,0x30,0x90,0x8A,0xEE,0x1F, 0xA6,0x00,0x01,0x02,0x
  • hello, i have get new ipc vin 2011 china is: LSGPC53R3BF000379   ipc_ltz_cn_2011_final.zip
  • i'm check  with FX3 then different is: Indication Calibration 95989747 Unknown Warning Calibration 95051419 Unknown
Is it your original VIN?, may be mistake in one symbol? I had same issue  🙂  can you make screenshot that part of your’s dump?
14 hours ago, kamilot said:
Đây có phải là số VIN gốc của bạn không?, có thể bị nhầm lẫn ở một ký hiệu? Tôi gặp vấn đề tương tự   🙂   bạn có thể tạo ảnh chụp màn hình cho phần kết xuất của bạn không?
my org ipc is 272, new ipc i change vin using dps before read eeprom. Please check image attachmentimage.png.7719c3dbdaeb5a205225ae7d4b4659f8.pngimage.png.000d8e5d7dc96245afe4390870bc4669.pngimage.png.93a3be0d301fe5daca1da65c94bf0c8c.png
Hi bro, you can find location part number in file bin of eeprom of IPC
And i'm want know flash ipc different part number is allow?
ipc_lar_new1_en.bin
I fixed the immo error and not displaying the km as follows:
To get rid of the immo error in GDS2 I reprogrammed the key
To display km as in BCM, change this value to 00
The problem is that my car has automatic wipers but the indicator light seems to be unprogrammed. Do you know which calibration file to edit?image.png.f0e0ec1009c234e49b77ddc38479dbe7.pngimage.png.55a035f62d995fff3222158857643b9d.png
Good job, bro! Thank you for sharing information to Me 🙂
about autowiper- my effort to get another Operation System make died my IPC 😂 Error A2, and it not working now.. be careful with it 🙂
sorry, my ipc the same when tryng enabled autowiper
Oooh 🫨 it bad news.. what kind of Operation System did you try to flash?)
I am already have idea, why we has this error. Cos ours panels need 12 calibration files ( 12 is emty, but usually it upload at factory), but sps give us only 11. I have no idea, how to write empty calibration…
I am flash random from opel, and now ipc work.. but not good 🤣
On 2/4/2024 at 7:46 PM, kamilot said:
Look here at $42 - it’s what we need to recovery our panels 🙂
I think position number 12 is unnecessary, but first I need to get the ipc working again. Can you give me the vin number to get the opel file like you said
try this one: W0LGT67M291079114
I tried, the ipc is up but the background mode is now more optimal than usual. In addition, the automatic wipers are still not displayed. you have not resolved it yet
Hey,
0xA6,0x00,0x01,0x02,0x03,0x04,0x05,0x06,
    00 - 01 DOOR_AJAR_INDICATOR_ENABLED
       - 02*DIESEL_PARTICLE_FILTER_INDICATOR_ENABLED
       - 04*CHANGE_OIL_INDICATOR_ENABLED
       - 08 CARGO_DOOR_AJAR_INDICATOR_ENABLED
       - 10 BULB_OUTAGE_INDICATOR_ENABLED
       - 20*CRUISE_ON_INDICATOR_ENABLED
       - 40*CRUISE_ENGAGED_INDICATOR_ENABLED
       - 80*FRONT_FOG_LAMP_INDICATOR_ENABLED
    01 - 01 RAINSENSE_INDICATOR_ENABLED
       - 02*PARK_ASSIST_INDICATOR_ENABLED
       - 04 ELECTRIC_COLUMN_LOCK_INDICATOR_ENABLED
       - 08*COMPETITIVE_MODE_ESC
       - 10 COMBINED_AJAR_INDICATOR
       - 20 LANE_DEPARTURE_INDICATOR_ENABLED
       - 40 DIESEL_EXHAUST_FLUID_INDICATOR_ENABLED
       - 80*ACTIVE_FRONT_STEERING_INDICATOR_ENABLED
You have to do this manually, there will be no RPO code enabler in the xml file for this...
Have fun...
Greetings, Toby
9 hours ago, E-Ing-X20XEV said:
Hey,
Have fun...
Greetings, Toby
my file indicator of ipc, you can tell me location in file enabled autowiperimage.png.043bed3adba0695f4979832d1f5b7d59.png
Hey,
Have fun...
Greetings, Toby
sorry, i'm add a06 did the same image but auto wiper not active lightimage.png.7c88454ea116f024b784cd995c32434d.png
Hey,
please set the ParamDefaultValue to "01" and try again.
It is just a guess, I haven't done this yet, but I will check it on my Astra this weekend.
On 2/7/2024 at 3:58 PM, E-Ing-X20XEV said:
Hey,
i'm trying add new option and display in screen when enabled auto wiper, then indicator not active lamp when i'm trying change indicator Byte 1-Bit 0 configuration DID
It is problem of Operation System, I think) try to switch on all indicators via gds2 test function)
i'm think problem OS (test enabled all indicator then all indicator active not include auto wiper), function display normal but dimming screen verry low when headlight on. You have the same issue?
I'm fix dimming screen is verry ok
7 minutes ago, kamilot said:
Yes, i have same problems, cos i have same ipc and same OS 😄
We cannot back to orginal 11 file, using dps flash and have error
yes, but I want use some like iprog or nec programmer, and look how it work inside) but now I don’t have such many time.. (((
kamilottungnv93pt
you need the Utility File when you compile the archive.
The Utility File lies along with the calibration files when you merge the calibrations via sps, but when you check on tis2web its number is not there, but it is in the folder.
this is a screenshot using my bcm as an example
image.png.7d99b717575dbce840e42626dbb11729.pngimage.png.e7b06a803197e8ae5e750d0e87f21263.png
12 hours ago, Slava Colpak said:
kamilottungnv93pt
Thank you, but ours dps archive created correctly and with utility file include. We have problem with last calibration file - Display background calibration 🙂 It must be empty...but when we try flash another OS, something change at flash memory and now, when we try flash stock OS -- we have trouble: IPC wait for 12 cal file, but it is not at SPS archive..
P.S.: It is only my mind, other guys from this forum think I'm wrong...
I have nothing to say yet, need more time for it.
P.S. #2: You can look at this thread:
chicking ABOMAZEN kobrak16 alatka asd Daniil_Ast Obada Alrifaee Abraham suarez Zafar_ VNautorepair Slava Colpak Rusnet1 SHARAWI exc11 antonsteering aaronprg dogwulf
