DPS Program failed
did you try to return tcm original calibration,,  it so easy to recover if you have hptuner,,
  • Replies 25
  • Views 4.4k
    another module "sof bricked" due not understanding DPS packages construction. Is issue with calibrations position. Position is stated in VIT2. Some modules required to be manually configured as DPS, d
  • So the DPS calibration files in the archive were not downloaded using the VIN that was already stored in the TCM? If not, try using the VIN that was in the TCM to download the files from SPS, then try
  • In that case if not possible, if he has the other TCM he could use that with the VIN from this TCM in sps. I had this same issue with an ECM and SPS was able to recover it using an MDI2,
Shifty artur minasyan PaulyVoltMan cleison kitsaras jjagel tahoecoding Adelin Ahmy veeeeight redcamaro jarrod early Nagana ajmiles AutoOpel hootydavis Zachariah Alp Tekin Galaxie simaservis
