Calibration K109 & K182
Solved by Robi_X
20 minutes ago, tobiasp said:
Hello, i have the same with a File from a Videomodul.
Can someone help me or make a File for me? The Original Files i have here
You need an archive for DPS from from SPS cached files?
Post files here.. I or another forum member can do this easily.
  • Replies 36
  • Views 3.5k
  • Soo i got it working after hours of searching and testing. The culprit was really the VXDiag with its buffer size or timing error. I change the max Buffer and Programmed.  ProgramLog Ca
    Will hook up my bench later or tomorrow. Sorry, too busy at work these days…
    Nah, these modules require specific way of constructing dps package and manually update VIT2 file. Have similar issue with BCM on Meriva B.
Yes i can do it. But there i have the Problem with the Buffer.
I have two Files and at both there i have the Problem [4099] Framepad
spsDebug.zipOriginal.zip
That's a hefty file (24+ Mb).. you have mentioned in the other post that you have VXdiag.
OP was having issues with flashing a much smaller file.. so you may be limited by the hardware here.
Whatever-this-is.zipDon't mind the filename lol, try this one, ready to go for DPS
ok i test it but not work.
ProgramLog.Txt
And it is the K157 Videomodul.
I Used PIN: 1 and ECU ID: 6D
ProgramLog.Txt
Try it again, something else happened this time... you didn't even get past security unlock. Did you run 33.3? Don't try 83.3. You didn't get near as far so something else happened this time.
ok i test it again. At the Moment he load veryyyy slow. 1 % in 4 minutes. I write when i have 100% or a error.
Thanks for the first time
loading.Txt
He load and load 49% in 2 hours.
Hello, all is Loading and the Files back at the Modul.
It needs rounnd about 5 hours to reloud.
@ codebuilder Thanks very much for help
You're welcome! Some of those aren't great haha, glad it worked!
loading.Txt
Yes, that was much better! Slow, but better... I haven't fully tested the buffer limits of the VCX as this is legit, just a hobby for me. Glad that worked :)
M Ch syciu Anderson Fonte kitsaras Adelin regloops ViCo2 mechanix kobrak16 Arbe_gtc Robi_X Nagana hootydavis DaOneDuc apetrushenko tan tan stensin Galaxie Mindaugas Cernius KiT71
