Calibration K109 & K182
Does anyone have K109 Camera and K182 Parking calibrations for W0LBE6EC3G8002786?
Part number K109: 39019605
Part number K182: 39050500
Solved by Robi_X
  • Replies 36
  • Views 3.6k
  • Soo i got it working after hours of searching and testing. The culprit was really the VXDiag with its buffer size or timing error. I change the max Buffer and Programmed.  ProgramLog Ca
    Will hook up my bench later or tomorrow. Sorry, too busy at work these days…
    Nah, these modules require specific way of constructing dps package and manually update VIT2 file. Have similar issue with BCM on Meriva B.
Will check tomorrow if no one source them
No one source them till now😅
Would it also be possible to get the XML from it if any exist?
I was able to get all files.
Does anyone know what went wrong?ProgramLog K109 fail.TxtK109.zip
Before:
After:
Maybe incorrect calibrations. There are modules that, if they do not accept the calibrations, remain in that state 01. You can load it again.
I think you have a problem with packaging.
10 hours ago, Mindaugas Cernius said:
Try again.
Nop still fails.
How can i do it, or is it not possible?
I also found this Thread about VXdiag having Problem with big buffer or so
Do you mean that.
What do I have to enter in Man-HW / Sup-HW, or do you have to enter anything at all?
21 hours ago, Robi_X said:
Nop still fails.
Ahhh yes, two of us tried with VXDiag's on an SDGM using Low Speed and ran into timeouts like crazy.  I have another clone MDI2 and it wouldn't do the SDGM either.
In your case though, it's retrying but it's making it to the end.  You're getting the same error as the other post I've just responded to.  I'll ask the same, is this for sure the same part?  Do you have the old VIN and new VIN and can get the files for both?  (I can't download those ones unfortunately).  In your case too, it rejected the OS stating it's not ready or there's not enough space to save it based on the error code.
12 hours ago, Robi_X said:
Do you mean that.
yes, u should fill all relative data. As well need all calibration to be in correct order.
@codebuilderdue not populated VIT2 wiht correct data, him module now is "empty". I do this mistake before, until get to learn how should be done. Few "bricked" modules and couple days/nights reading and testing.
I saw that too....  they should try it as it's an important step but the only step I'm seeing it should have hit this early is the skip OS.  I could be wrong though, I'd still try the VIT2 first before anything.
Vin is the same, and dont have the old file just newASTRA K W0LBE6EC3G8002786.zip
On 12/25/2023 at 7:25 PM, Robi_X said:
Part nummer is 39019605 and it stand an the module.
I try the VIT2 and see if it works.
Hello my friend,  is there a way to download or buy the program you are using in the picture?
I tried but Still fails😢ProgramLog camrea fail vit 2.Txt
Is it possible to change the buffer size of DPS.
Or is that the size the module needs and can work?
Your package isn’t build correctly.
16 minutes ago, Lyubomir Krastanov said:
correctly
Are you able to build it correctly?
Highly possible, but not guaranteed
Would be pretty nice 🙂
ProgramLog Camera Success.Txt
Still a small thing there is no Seed anymore. Just $0000. Is that a Problem?
GCI_Log Camera Success.Txt
The Seed was before $4CB4
Hello, i have the same with a File from a Videomodul.
Can someone help me or make a File for me? The Original Files i have here
M Ch syciu Anderson Fonte kitsaras Adelin regloops ViCo2 mechanix kobrak16 Arbe_gtc Robi_X Nagana hootydavis DaOneDuc apetrushenko tan tan stensin Galaxie Mindaugas Cernius KiT71
