Cali required
9 minutes ago, Lyubomir Krastanov said:
Don’t tell me where not understand files where I sent you. Is a complete. Setup folder contain files for setup and configuration function, blob file - use it to identify files structure.
I think it was my fault as I looked on tis2web at my existing VIN by mistake, I think I have correctly built both archives now, I will attempt to program and report.
  • Replies 43
  • Views 2.9k
    Interesting, I cannot find these, but can give you mine with RVC mine is 14 plate and I have RVC activated.   if you want specific for these for your VIN, I will download them. Next time whe
    that is all files, enjoy hmi.rar
    that should be files for your radio. try and report, just have lunch break RADIO.rar
H1
The A11 programmed fine but the HMI said there was an error programming.
Now I cannot read the HMI and when i try to program it comes back with an error stating Not all ECUs responded properly.
Any ideas?
you have to choose the right pin and baud rateimage.png.fcdcd0446d644a20efd501a0c023fdb9.png
On programming don’t opt for global a, leave as default and flash it.
This is what i used to flash A11 which worked, it's HMI i'm trying to flash on 6&14 I don't have any options for different baud rates for that.  Do you think I should reflash radio first any retry?
My copy defaults to Global A, what options should my default be?
Tried again with thoae settings and same result.
Initializing Programming Session - v4.51.0000
Programming Initialization
Loading Calibration Files C:\DpsArch\2014_Insignia_HMI_2_0.zip!
The VIT2 does not contain Part Number Information (VIT not populated)!
>> DLL Path: C:\Program Files (x86)\GM\J2534Wrapper\J2534Wrapper.dll
>> C:\ProgramData\VCX\Apps\PASSTHRU\VCXPT32.dll
>> ALLScanner;VXDIAG;04.04;;
>> Firmware Version: 1.9.4.3 VCX-NANO N52GM20366, DLL Version: 04.04.210328, API Version: 04.04
>> Startup
>> Setup Base Mapping Matrix
>> Determine subnet configuration
  19:56:14.971<[.H..] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012]
  19:56:14.971>[.H..] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012] TxMsgType
>> Available subnets:  HS-CAN
  19:56:15.002<[.H..] 00 00 01 01 FE 02 1A B0 00 00 00 00 [0012]
  19:56:15.002>[.H..] 00 00 01 01 FE 02 1A B0 00 00 00 00 [0012] TxMsgType
  19:56:15.013>[.H..] 00 00 07 EA 03 5A B0 18 [0008]
  19:56:15.237>[.H..] 00 00 07 E8 03 5A B0 11 [0008]
  19:56:15.237>[.H..] 00 00 06 52 03 5A B0 8F 00 00 00 00 [0012]
  19:56:15.237>[.H..] 00 00 06 41 03 5A B0 40 14 00 84 7E [0012]
  19:56:15.237>[.H..] 00 00 06 42 03 5A B0 31 00 00 00 00 [0012]
  19:56:15.237>[.H..] 00 00 06 43 03 5A B0 28 [0008]
  19:56:15.237>[.H..] 00 00 06 54 03 5A B0 2B 00 00 00 00 [0012]
  19:56:15.237>[.H..] 00 00 06 49 03 5A B0 72 00 00 00 00 [0012]
>> Base Mapping Matrix:
>> ECU 0x18 on HS-CAN (ReqCANId: 0x000007E2, RspCANId: 0x000007EA)
>> ECU 0x11 on HS-CAN (ReqCANId: 0x000007E0, RspCANId: 0x000007E8)
>> ECU 0x8F on HS-CAN (ReqCANId: 0x00000252, RspCANId: 0x00000652)
>> ECU 0x40 on HS-CAN (ReqCANId: 0x00000241, RspCANId: 0x00000641)
>> ECU 0x31 on HS-CAN (ReqCANId: 0x00000242, RspCANId: 0x00000642)
>> ECU 0x28 on HS-CAN (ReqCANId: 0x00000243, RspCANId: 0x00000643)
>> ECU 0x2B on HS-CAN (ReqCANId: 0x00000254, RspCANId: 0x00000654)
>> ECU 0x72 on HS-CAN (ReqCANId: 0x00000249, RspCANId: 0x00000649)
>> InitiateDiagnosticOperation (0x10) service with sub-func. 0x02 (disableAllDTCs)
  19:56:16.739<[.H..] 00 00 01 01 FE 02 10 02 00 00 00 00 [0012]
  19:56:16.739>[.H..] 00 00 01 01 FE 02 10 02 00 00 00 00 [0012] TxMsgType
  19:56:16.848>[.H..] 00 00 07 EA 03 7F 10 12 [0008]
  19:56:16.879<[.H..] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012]
  19:56:16.911>[.H..] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012] TxMsgType
  19:56:16.911>[.H..] 00 00 07 E8 01 50 [0006]
  19:56:16.911>[.H..] 00 00 06 41 01 50 B0 40 14 00 84 7E [0012]
  19:56:16.911>[.H..] 00 00 06 52 03 7F 10 12 00 00 00 00 [0012]
  19:56:16.911>[.H..] 00 00 06 43 01 50 [0006]
  19:56:16.911>[.H..] 00 00 06 54 01 50 B0 2B 00 00 00 00 [0012]
  19:56:16.911>[.H..] 00 00 06 49 01 50 B0 72 00 00 00 00 [0012]
  19:56:18.424<[.H..] 00 00 01 01 FE 01 28 00 00 00 00 00 [0012]
  19:56:18.424>[.H..] 00 00 01 01 FE 01 28 00 00 00 00 00 [0012] TxMsgType
  19:56:18.456>[.H..] 00 00 07 EA 03 7F 28 22 [0008]
  19:56:18.487<[.H..] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012]
  19:56:18.518>[.H..] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012] TxMsgType
  19:56:18.518>[.H..] 00 00 07 E8 01 68 [0006]
  19:56:18.518>[.H..] 00 00 06 43 01 68 [0006]
  19:56:18.518>[.H..] 00 00 06 41 01 68 B0 40 14 00 84 7E [0012]
  19:56:18.518>[.H..] 00 00 06 54 01 68 B0 2B 00 00 00 00 [0012]
  19:56:18.518>[.H..] 00 00 06 49 01 68 B0 72 00 00 00 00 [0012]
  19:56:18.518>[.H..] 00 00 06 52 01 68 10 12 00 00 00 00 [0012]
  19:56:18.518>[.H..] 00 00 06 42 01 68 B0 31 00 00 00 00 [0012]
>> !!! Not all expected ECUs responded positively!
>> ReturnToNormalMode (0x20) service
  19:56:20.143<[.H..] 00 00 01 01 FE 01 20 00 00 00 00 00 [0012]
  19:56:20.143>[.H..] 00 00 01 01 FE 01 20 00 00 00 00 00 [0012] TxMsgType
  19:56:20.174>[.H..] 00 00 07 EA 01 60 [0006]
  19:56:20.206<[.H..] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012]
  19:56:20.237>[.H..] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012] TxMsgType
  19:56:20.237>[.H..] 00 00 07 E8 01 60 [0006]
  19:56:20.237>[.H..] 00 00 06 41 01 60 B0 40 14 00 84 7E [0012]
  19:56:20.237>[.H..] 00 00 06 54 01 60 B0 2B 00 00 00 00 [0012]
  19:56:20.237>[.H..] 00 00 06 49 01 60 B0 72 00 00 00 00 [0012]
  19:56:20.237>[.H..] 00 00 06 43 01 60 [0006]
  19:56:20.237>[.H..] 00 00 06 42 01 60 B0 31 00 00 00 00 [0012]
  19:56:20.237>[.H..] 00 00 06 52 01 60 10 12 00 00 00 00 [0012]
I'm wondering if perhaps the Radio didn't program correctly?
Unplug the radio conectors and try programming with DPS without ACC.
So tried everything I can think of. I disconnected the silverbox that didn't work either.
Tried another silverbox which obviously came up with theft lock. Tried programming again with new radio in theft lock status, same result.
Changed VIN on new A11 radio and flashed to get off the theft lock, still same result.
I can only assume that the HMI unit is faulty? I have another one but it's an HMI2.5 but I don't have the correct calibration files for that to test it.
Attached are pics of the replacement HMI and Radio if someone could supply the calibration files to try those that would be amazing.
Calibration depend of car where will be installed.
Oh sorry, Into my car which is W0LGT8EM1E1046713
Try W0LGT8ES9E1196857 that has the same equipment.
Check if the HMI has +12V and(ACC)
I tried again with radio disconnected and no ACC and I get a different error
Loading Calibration Files C:\DpsArch\2014_Insignia_HMI_2_0_RVC_Activation.zip!
>> Startup
  22:35:36.517<[.H..] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012]
  22:35:36.517>[.H..] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012] TxMsgType
  22:35:36.548<[.H..] 00 00 01 01 FE 02 1A B0 00 00 00 00 [0012]
  22:35:36.548>[.H..] 00 00 01 01 FE 02 1A B0 00 00 00 00 [0012] TxMsgType
  22:35:36.580>[.H..] 00 00 06 41 03 5A B0 40 14 00 84 7E [0012]
  22:35:38.095<[.H..] 00 00 01 01 FE 02 10 02 00 00 00 00 [0012]
  22:35:38.095>[.H..] 00 00 01 01 FE 02 10 02 00 00 00 00 [0012] TxMsgType
  22:35:38.142>[.H..] 00 00 06 41 01 50 B0 40 14 00 84 7E [0012]
  22:35:38.173<[.H..] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012]
  22:35:38.205>[.H..] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012] TxMsgType
  22:35:39.720<[.H..] 00 00 01 01 FE 01 28 00 00 00 00 00 [0012]
  22:35:39.720>[.H..] 00 00 01 01 FE 01 28 00 00 00 00 00 [0012] TxMsgType
  22:35:39.767>[.H..] 00 00 06 41 01 68 B0 40 14 00 84 7E [0012]
  22:35:39.798<[.H..] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012]
  22:35:39.830>[.H..] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012] TxMsgType
>> ReportProgrammedState (0xA2) service
  22:35:41.392<[.H..] 00 00 01 01 FE 01 A2 00 00 00 00 00 [0012]
  22:35:41.392>[.H..] 00 00 01 01 FE 01 A2 00 00 00 00 00 [0012] TxMsgType
  22:35:41.736>[.H..] 00 00 06 41 02 E2 00 40 14 00 84 7E [0012]
  22:35:41.767<[.H..] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012]
  22:35:41.798>[.H..] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012] TxMsgType
>> Number of detected programmable ECUs: 1
  22:35:43.377<[.H..] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012]
>> Enable Programming Mode
>> ProgrammingMode (0xA5) service with sub-func. 0x01 (requestProgrammingMode) on HS/MS-CAN
  22:35:43.487<[.H..] 00 00 01 01 FE 02 A5 01 00 00 00 00 [0012]
  22:35:43.487>[.H..] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012] TxMsgType
  22:35:43.487>[.H..] 00 00 01 01 FE 02 A5 01 00 00 00 00 [0012] TxMsgType
  22:35:44.736>[.H..] 00 00 06 41 01 E5 00 40 14 00 84 7E [0012]
  22:35:44.767<[.H..] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012]
  22:35:44.798>[.H..] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012] TxMsgType
  22:35:46.423<[.H..] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012]
>> ProgrammingMode (0xA5) with sub-func. 0x03 enableProgrammingMode)
  22:35:46.455<[.H..] 00 00 01 01 FE 02 A5 03 00 00 00 00 [0012]
  22:35:46.455>[.H..] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012] TxMsgType
  22:35:46.455>[.H..] 00 00 01 01 FE 02 A5 03 00 00 00 00 [0012] TxMsgType
  22:35:48.158<[.H..] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012]
>> Enable MixedFormatFrames (ignore failure)!
Establishing Connections
Preparing Controller
Utility File:  22892123_Utility.BIN
Utility File Step=01 Opcode=01
>> Target address 0x008F not in mapping matrix!
Utility File Step=02 Opcode=F1
Utility File Step=03 Opcode=F2
Utility File Step=04 Opcode=34
>> !!! ReqCANId not set (simulate timeout)!
Utility File Step=2B Opcode=FB
Utility File Step=2C Opcode=FC
  22:35:48.673>[.H..] 00 00 01 01 FE [0005] ExtAddress TxDone TxMsgType
Utility File Step=2D Opcode=EE
  22:36:01.283<[.H..] 00 00 01 01 FE 01 20 00 00 00 00 00 [0012]
  22:36:01.283>[.H..] 00 00 01 01 FE 01 20 00 00 00 00 00 [0012] TxMsgType
Will upload my calibrations later for test purposes.
Perfect thank you.
Ps I didn't ignore your PM I'm just not able to reply.
Shifty samer Robi_X jjagel exc11 Alp Tekin hassan77h zamich85
