Techline account disabled
Hey guys, tlc banned my account I was using. Now I can’t even use delco tds either.  So now I’m forced to use a VPN. Anyone have access to dealer programming that wants to share login creds for a price. I don’t expect free. I have several cal files and virgin dumps I could trade, I don’t use it much. Just for hobby stuff and local module repairs.
I wish we could all band together and make a database of calibration files to not need online programming. send me a dm!
  • Replies 37
  • Views 7.6k
  • Yeah true. Nothing last forever. That's why we evolve. Someone who knows Java very well will dump that GM SPS database soon and hand it to us 🙂
  • Flex_user
    Flex_user
    100% can verify my emulator works with a dealer account when used correctly without kickoff or ban.
  • Yep, ACdelco recently start banning accounts for using the emulator tool. Someone said it's fine to use the emulator tool on a dealer account with only 10 VINs per day.
What were you doing on the account for them to ban you? Were you using an emulator tool or using many VINS on the account?
Seems TLC is now onto us🙂
Emulator tool, unfortunately.
they blacklisted my IP, and froze all tlc accounts I had used on my ip in the past. I uninstalled the emulator. Will never do that again..
yes, I received a message from my brother who lives in the USA \ and works for GM auto repair bars\ the TLC program has finished support on windows 7 and 8 64 bits\ only now 10 wih pro 64 bits are looking for the original image 21H1 only this image supports the corporate license key
I also noticed that they build the techline around a Intel 5.0 or above processor, apparently having AMD also throws a red flag. Its documented in the resources info on the delco tds site. TLC support confirmed as well.
and that's what on windows 7 and 8 64 bit windows does not open a window to select a scanner not in SPS2 mode and GDS2\
also in spss on acdelcjotds \ there are now two types of order 1- sps 40 euros\2 -ps2 from 10 euros to 180 euros see photo
2 minutes ago, Viktor Pobeda said:
Interesting, this must be a overseas market option?
US spec delcoTDS doesn't list an hourly option under SI
That would be nice, but even having an overseas account, wouldnt have access to US spec controllers..
I would gladly pay for an hourly option if it was offered here.
both those options have been available when connecting from europe for some time, they're not explained very well...  what looks like the cheap option for sps2 programming is I believe only for older vehicles using the tech2 ... I did try using it for a 2014 vin last october, the SI worked fine but the sps2 just laughed and threw back an error message....
Troy that someone is stupid Greedy guy, we both know that ☺️
Yeah true. It's not like we're gathering calibration files from GM SPS to program Ford or Toyota vehicles, we're programming GM vehicles. Although we're using unorthodox methods to repair or modify our GM vehicles, we are all still a part of the GM family and they still get our money one way or the other. GM needs to cut this crap and realise that the vehicle we need files for was made by them. What we do here is still beneficial to them GM.
GM, leave us be so we can get our files in peace.
Acdelco USA has geolocation embedded in their website. If you log on to their website from a European IP, it will show you the more expensive European price. If you use a VPN and pretend to live in the USA, it will show you the cheaper American price. The SPS uses the same database for both the USA and none USA IP.
так как я живу в РОССИИ, то МЕНЯ БАНЯТ  С 2022\01, поэтому я работаю на VPN сервере со статическим ip адресом, который не меняется а остается одинаковым на протяжении всей оплаты\при этом я выбираю максимальную скорость\вот если ТРОЙ разрешает в этой теме можно поделиться с проблемами VPN подключения и стабильности работы
and that's what I noticed here the main reasons are the following: 1- payment should be once a month, any choice from SI to SPS-SPS2 or buy for example GDS2 for a year, then they see on the site that you are working and give programming SPS2 \I work like this, my friend paid for a year GDS2 \ and I work in ACDecotds Europe \\ via VPN
Unfortunately, nothing lasts forever. It is a matter of time before GM starts to make it a little more difficult, for example, to use an account 500 times at the same time, etc...
  • Popular Post
  • 6 months later...
what is a emulator used for? does it still work with a dealer login?
The emulator is used to retrieve calibration files without having the vehicle present.
Thanks I figured that is what I was thinking it was for. Just trying to learn things and so far i'm not getting very far lol. Used SDMs are common here and so far I'm 0 for 2 on getting them to change the environment ID.
That is VIN. Pin is easy as is part of immo learn.
The first one was a 2013 malibu first year global A and it wouldn't change vin or the environment ID. The one I have now is a 2019 Canyon with 5 byte seed. The files on here would't do anything, just error when it tried to run. SPS did somehow change the vin but the sdm still sets a b3902 and the bcm sets a b3924 even after redoing all the key/immo learning stuff.
Because u doing it wrongly 🙂 it has procedures and steps.
Yes I went back and reread everything and found my mistake. So now I'm 1 for 2 lol
nicol Mohammed Khalid Shifty pollosuper jjagel LIUCHUAN Mudhif Ahmad Akmal Encrypted Owner Amplifier Pasha JD where are my glasGas Lyubomir Krastanov Tyler Mygrant John Stevens Jarektf Steve Nash aleks nik apetrushenko
