  • Open Club
  • 151 members
  • Free
What is ELR mod?
The Cadillac ELR and Chevrolet Volt shares almost Identical drivetrain components. GM came out with the Cadillac ELR in 2013 that has more power compared to the Chevy Volt. Some smart minds found a way to take the programming of the ELR and transfer it directly to the Chevy Volt resulting in more power for the Volt. This club will show you how to unlock the potential of your Chevy Volt or Cadillac ELR. Currently a group effort is being made to modify the code to suit customization needs. Please feel free to share any insight you may have on how to make more modifications.
The ELR mod on a Chevy Volt is is only available from 2013 to 2015 Volt:
2014 ELR mod specs
2013-2015 162 kW (217hp)
2016 ELR mod specs
2013-2014 180kW (241hp)
2015 180-191kW (241-256hp)
Cadillac ELR
2014 Cadillac ELR
Overview
Manufacturer General Motors
Production 2013–2016: 2,958 Units
Model years 2014 and 2016
Assembly United States: Detroit, Michigan (Detroit/Hamtramck Assembly)[1]
Designer
  • Exterior: Tim Kozub
  • Interior: Keith Fisher[2]
Body and chassis
Class Compact car[1]
Body style 2-door coupé
Layout Transverse front-engine, front-wheel drive[1]
Platform GM Delta II / GM Voltec[3]
Related
Powertrain
Engine 1398 cc EcoFLEX LUU I4 (gasoline)[1]
2014 Transmission
2016 Transmission
CVT Voltec 4ET50 multi-mode electric transaxle[1]
CVT Voltec 4ET55 multi-mode electric transaxle[1]
Hybrid drivetrain
2014 Total Power
2016 Total Power
Series hybrid[4]
162 kW (217hp) 295ft lbs (400 Nm)
233 kW (312hp) 373ft lbs (506 Nm)
Battery 16.5kwh (2014) – 17.1kwh (2016) kWh lithium-ion battery[1]
Range 340 mi (550 km)(EPA)[5]
Electric range (2014) 37 mi (60 km) (2016) 39 mi (63 km) (EPA)[5]
Dimensions
Wheelbase 2,695 mm (106.1 in)[1]
Length 4,724 mm (186.0 in)[1]
Width 1,847 mm (72.7 in)[1]
Height 1,420 mm (55.9 in)[1]
Curb weight 1,846 kg (4,070 lb)[1]
Chevrolet Volt
2012 Chevrolet Volt
Overview
Also called
Holden Volt
Opel Ampera
Vauxhall Ampera
Model years 2011–2015
Designer Jelani Aliyu
Body and chassis
Class Compact car (C)
Body style 5-door liftback
Layout Front-engine, front-wheel drive
Related Cadillac ELR
Chevrolet Malibu Hybrid
Powertrain
Engine
Electric motor
  • 1× 111 kW (149 hp)
  • 1× 55 kW (74 hp)
  • permanent magnet motor/generators
Transmission 1-speed Voltec 4ET50 Multi-mode electric transaxle
Hybrid drivetrain Series hybrid/Parallel hybrid (GM Voltec)[3][4]
Battery
  • 16.0 kWh lithium-ion (2011–2012)[5]
  • 16.5 kWh lithium-ion (2013–2014)[6]
  • 17.1 kWh lithium-ion (2015)[7]
Range
380 miles (610 km) EPA (2011–2015)[9]
Electric range 35 miles (56 km) EPA (2011–2012)[10]
38 miles (61 km) EPA (2013–2015)[9]
Plug-in charging 3.3 kW AC (2011–2015)
Dimensions
Wheelbase 2,685 mm (105.7 in)[2]
Length 4,498 mm (177.1 in)
Width 1,788 mm (70.4 in)
Height 1,438 mm (56.6 in)
Curb weight 1,721 kg (3,794 lb)
  • +VoltGuru changed the title to What is ELR mod?
  • Views 2.7k
  • Nicholas Trambitas
    Nicholas Trambitas
    I would check to make sure that your HPCM2 ECU is the same part# as what is installed on the ELR and that the pinouts are the same. If they match, I think you should be safe to try to flash the ELR HP
I have a 2014 ELR and I am new to the DPS scene. Can I just grab the HPCM2 calibration from a 16 ELR and flash it onto my car with DPS and unlock the additional power? Or is there physical hardware change that I need? Thank you
This guide is only for 2014 ELR power. 2016 ELR will have a guide in the future since it requires different hardware, changing wiring, and certain years need certain hardware replaced. You can't flash 2016 ELR hybrid2 firmware into any hybrid2 module 2011 - 2015 Volt. It will not accept it since the hardware is incompatible.
  • 4 months later...
On 2/14/2023 at 10:29 AM, lvulcan said:
Thank you for all of the hard work put in to realize/make this possible.
I have a VCX Nano and an SPS 2 subscription I used to successfully program a BICM I replaced on a "Propulsion Power Reduced" 2013 Volt I recently bought (battery is in great condition with only ~88,000 mostly highway miles on the car, I just had 0v reading on cells 43-50 when it was cold outside).
Would it be possible to apply the 2014 ELR mod with the software/hardware I have?
If not, what else should I need?
I want to show to family/friends what the Chevrolet Volt is really capable of, they still think I bought a glorified Prius.
I would check to make sure that your HPCM2 ECU is the same part# as what is installed on the ELR and that the pinouts are the same. If they match, I think you should be safe to try to flash the ELR HPCM2 calibration. I've seem others on the Facebook group do this mod and this is how I suspect that they did it. I'm not sure if the BECM needs to be reflashed as well
  • 10 months later...
I know I'm late to the show, but wondering.. I have a gen2 18 model Volt, the ELR mod is it for gen 2 cars or more hyperfocused on gen 1?
With additional KW, is this any harder on the drivetrain/battery lifespan for the Volt?
hassan77h bekatsilosani AMJar Kempp lvulcan GMcars extodd empowered Layne Bumgarner thxx ma_ko
