GM HMI 2.5 theft lock removal, unlock
Are you on pin 1?
  • Replies 106
  • Views 11.9k
    U doing in car or on bench?
    I use 4.52, but if you want drop me PM and will help you remotely
    As I say, use 6/14 and populate your VIN. If you cannot handle it let me know and will help remotely via anydesk
I donated the 150$ amount or whatever it is and downloaded the 4.46 dps from here, still same issue. Tried it on my wife's cadillac, same issue that doesnt have any issues, same thing.
2 minutes ago, BLKATSG said:
Are you on pin 1?
yes pin 1 33.3k
it tries to go much further if i do the 6 and 14 (which i know its for HMI). Actually, it goes all the way on pin 6 andnd 14, just says error during programming at the end which i read to ignore that message.
But doing pin 1 on either 33.3 or 83, no luck.
Using mongoose, drewtech, JLR
The log you shared is over HS-CAN line (500Kbps)
>> Available subnets:  HS-CAN
>> Target address 0x0080 not in mapping matrix!
In PIN 1 33,3 must works
Figured it out yesterday. It was my OBD interface. Didn’t have the DLC pins for that module.
On 8/1/2024 at 5:42 AM, Redsupra said:
yes pin 1 33.3k
MONGOOSE JLR doesn't work at all on pin 1. You can use Mongoose GM .
Yea I posted that above
GERMAN pupu14 Lorenzo Torres artur minasyan course gman Rumpel Enterlan Dtimov Anthony Gracia Talha Tariq cadydaddyx WhiteAndBlue dhzen stensin veetdoc DrJerry Faisal bin salman abdel Mahmoud El-Gammal loweperf
