GM HMI 2.5 theft lock removal, unlock
Hi Codebuilder, saw your message but can't send message. I do have DPS 4.48, so what else I will need a config file and then I buy HMI 2.0/2.5 Module VIN Number Relearn program is that all?
Super thank you Codebuilder!!
Christopher
  • Replies 106
  • Views 11.9k
    U doing in car or on bench?
    I use 4.52, but if you want drop me PM and will help you remotely
    As I say, use 6/14 and populate your VIN. If you cannot handle it let me know and will help remotely via anydesk
Christopher
Might be too new :).  I can send you something that might be close for now if you like?  What you'll need:
- VIN Number Relearn (for the HMI)
- Calibrations to set settings for your car (I might be able to get something close until I can get back into SPS)
AWESOME THANK YOU!!! I just got DPS 4.48 installed and looks like it will work...
Christopher
Oh yes still theft locked. I even get the Buick screen on my old radio, so a recap, original Camaro radio that looks like it's all good as with that GM GDS2 I was able to bypass the theft lock and was able to set time and look around.
Sorry to hear you can't get into SPS yet... I think the BCM and the Radio have the the correct VIN, just the HMI needs to be updated and from what I understand I just need the Calibrations that provide all of the features as I do have Nav and Sirus XM, + the Illumination setup all factory...
Last also is on the main display has Audio Off and think with the Calibrations file should fix and give me the Camaro splash screen?
Thank you so very much for taking your time helping me!
You don't know what you miss when you don't have it anymore!
Also for everyone I did attach a cpu fan to the bottom of the original HMI unit and made no difference, and if anyone goes into my issues I hope this helps..
Also for everyone I did attach a cp u fan to the bottom of the original HMI unit and made no difference, and if anyone goes into my issues I hope this helps..
Load this one up and you should be good.
1G1FD3DS2H0145539-2017-Camaro.zip
So I fully understand, I need to purchase the HMI 2.0/2.5 Module VIN Number Relearn? Or is this for the DPS 4.48? I'm very new to all of this. Maybe I saw here a video on how to do this?
 Really appreciate yours and everyones help with this!
Christopher
Christopher
No worries!  Run DPS, go into Programming, hit Select Cal and pick the ZIP file I've sent you, pick pins 6 & 14 (should be default) and hit program.  The key needs to be in accessory for the HMI at minimum though (or it has to be awake).  It'll take like 2 minutes at most
Wow, this sounds easy! I was not sure as I was thinking I would need to unzip it first but no? Ok confirm Pin 6 & 14 and hit Program, and the key in the car and the ignition on but not the engine.
I will report back ASAP...
Thank you and this site!
Christopher
Christopher
Definitely don't unzip it and don't rename it :).  If you rename it, DPS doesn't like that the .tbl name doesn't match.  If it's theft-locked, you're probably going to have to get Troy's HMI learner.
Got it! Anything I should do first before I do this other then having the HMI awake?
So cool thank you!
Christopher
So cool thank you!
Christopher
Nope, you should be good.  You can't hurt these things!  The worst you do is upload like a Cadillac one and you've got the wrong boot logo haha.  Don't upload a 2.0 to a 2.5 though, that breaks it (but can be recovered with a 2.5).
Sounds like in car, replacement but I could be wrong.
100% in the car as from what I have read it needs the BCM and other modules to communicate?
Thank you for the question.
Christopher
I presume if ask to “awake” module is like on bench. In car module been woken up by radio and bcm
Yes 100% I have a 2.5 HMI, as I read here about that here... Awesome site!
Christopher
Christopher
Not so much, the module just needs to be awake like Lyubomir stated.  I usually do HMI's in-vehicle in accessory so I'm not draining as much.  On the bench it's a bit different.
Not 100% sure not all that in to all of this, I was expecting to have the acc/ignition on to do this and think it should take a minuet or so then close down DPS and unplug the XVdiag and shut off the Acc/ignition and then star the car right?
So cool!
Christopher
So cool!
Christopher
Just put it in either accessory or ignition on, it'll take like maximum 2 minutes (and that's stretching).  You don't have to start the car, just turn the key off after programming, wait 30 seconds, turn it back on.  If it still says theft locked, like I say, you'll need Troy's HMI VIN learn but it will be calibrated to what you had at least.
Ah ok I see. I will give it try Monday night and report back...This is because your files in DPS 4.48 will calibrate the eBay HMI but still may still see the original VIN then get Troy's HMI Vin learn? Correct?
Thanks so very much!
Christopher
Getting an error "Error occurred FERGANA Programing.. I had to choose pin 6 &14 in the Diagnostic Pin, but what about Vehichitecture it is on Other, my choices are GM Global A or Global B GM GEM? I think its Global A?? Don't want to mess it up. I am in USA.
Your settings are ok, 6&14. Global A/B/Other doesn't matter for this.  And don't worry, it's very difficult to break these.
Can you attach the log?  It'll be in C:\DPS\Logs - programlog.txt
Nope emptly.
5 minutes ago, ZmanCamaro said:
Nope emptly.
Can you send a screenshot after you attempt?  I can't recall what that error is off of the top of my head (I've seen it).  You've installed the drivers, etc ok?
Here's a pic
GERMAN pupu14 Lorenzo Torres artur minasyan course gman Rumpel Enterlan Dtimov Anthony Gracia Talha Tariq cadydaddyx WhiteAndBlue dhzen stensin veetdoc DrJerry Faisal bin salman abdel Mahmoud El-Gammal loweperf
