Incorrect Immobilizer Identifier Propagating to All Nodes In-Network With the Gateway
Hey guys, I'm new here, so sorry if this post would be better fit under a different forum. Just let me know and I can repost it elsewhere.
I've got a real doozy here, so get ready for a story. I'll tell you guys exactly as it happened so there's good documentation of this specific failure; anyone not interested in reading a book, the TL;DR will cover it in less detail.
TL;DR:  An improperly remanufactured HMI has managed to write its original vehicle's immobilizer identifier to 4 other modules on this 2014 Cadillac SRX Luxury 3.6L V6 FLX FLEX FI, and according to numerous sources it will only continue to spread. Once it reaches a module that is integral to the immobilizer system, the vehicle will become a no-start. I need to find a way to either manually put the correct identifiers back into these 4 modules or find a way to properly virginize them. I'm planning to buy the Xhorse Multi-Prog programmer to attempt this; if any of you have other tools you recommend over this one, please let me know. I'm completely new to this, so basically any tips you guys have are much appreciated. Has anyone here ever run into this issue before?
First off, I'm a professional mechanic. I specialize in electrical diagnostics and get a very high volume of vehicles, therefore I get the chance to see some real weird shit; this is no exception. It started as a simple parasitic draw on a 2014 Cadillac SRX Luxury 3.6L V6 FLX FLEX FI. I diagnosed it and found the Human Machine Interface Control Module was causing the parasitic draw. Once the part was delivered, I installed it, programmed it using SPS2 and an MDI2, ran it through the set up procedure using SPS2 and an MDI2, then scanned it for DTCs. I found DTC B3902:00 was set in the HMI, indicating the remanufactured unit I had installed was not fully virginized during remanufacturing. After cycling the key a few times, I rescanned the vehicle and found that DTC B3902 had now been set in the Instrument Panel Cluster, Electronic Brake Control Module, and the Climate Control module, as well as the HMI. This DTC is for Incorrect Immobilizer Identifier Received. General Motors official work-flow for this fault is to reprogram the module, then run the vehicle through an immobilizer relearn; if the DTC still returns, then the module must be replaced. I followed these instructions, but found that the DTC was still active.
Once I saw this, I called AC Delco's Diagnostic Hotline. I found that this exact issue has been documented, and never has a happy ending. In very rare cases on Global-A vehicles, when a used module is installed into a new vehicle while still containing the previous vehicle's security identifiers, the replacement modules' incorrect security identifiers can propagate, being rewritten to other modules on the networks. ACDelco has only seen this happen a couple dozen times, but it is a confirmed issue. In every case, all of the vehicles modules eventually relearned the incorrect security identifier, and the only fix is to replace every affected module at once, i.e. every module connected to the gateway. Once the incorrect identifier spreads to any of the modules integral to the antitheft system, the vehicle will also no longer be able to start. I was told to immediately remove the HMI from the vehicle to prevent further modules from being affected, to install a brand new one, and then after programming the HMI, to perform another immobilizer relearn on the vehicle.
Thankfully, in my case it had only spread to 3 others so far. I ordered a properly remanufactured HMI through GM and followed their instructions, but found the B3902 was still set in the IPC, EBCM, and HVAC. The only solution I was given by AC Delco was to replace all 3 modules with new ones. I decided to take the vehicle for a test drive to see if any new DTCs would set; rather than finding new DTCs, I found that the Inflatable Restraint Sensing and Diagnostic Module was now setting B3902 as well. No other DTCs are present in the vehicle. The incorrect security identifier is still managing to continue propagation to other modules despite the HMI being replaced; absolute worst case scenario. I reached out to a couple of my contacts that deal with programming issues on a large scale, and they also said they have seen this happen to Global-A vehicles. Much like AC Delco's reports, every time they had seen this issue, all modules in-network with the Gateway had already been affected. One of my contacts said that he had fixed these issues in the past by removing the MCUs from each module's PCB's, virginizing them, reinstalling them, then reprogramming all modules on the vehicle. Sadly he said that these jobs were all far too time consuming and not something he would be interested in ever touching again, so im still on my own.
I know all of this sounds crazy if you've never heard of it happening before, but I've had numerous independent sources confirm it as a known, extremely rare failure. Every single one agreed that it shouldn't be possible, but it is. My next step from what I can tell needs to be purchasing a programmer that will let me manually edit the bin file. From there I seem to have 3 options that I can think of.
  1. Figure out what hexadecimal bytes contain the immobilizer/environment identifier, determine the vehicle's correct identifier from an unaffected module, and write the correct data into the affected modules.
  2.  Find a way to properly virginize the modules, likely requiring me to purchase the virgin .bin files and write them to the affected modules.
  3.  The obvious one that I'm trying to avoid, replace all affected modules.
If anyone here can come up with better options, I'm open to them. I'm planning to buy the Xhorse Multi-Prog Programmer here shortly so I can get started with this soon; if anyone here has a better tool they recommend over this, please let me know. Once I get the bin files I'll be sure to post them here. Has anyone here personally dealt with Global A B3902 propagation like this, or successfully corrected/virginized affected IPC, EBCM, HVAC, or SDM modules?
  • Replies 20
  • Views 316
  • The HMI is not part of the immobilizer, so it is extremely unusual for that DTC to be triggered by an HMI replacement. The environment identifier is used to prevent the swapping modules between vehic
  • Hi, "incorrect immobiliser identifier" you will get this DTC whenever you install a used module that's on the GM vehicle's secured system, for example, a used BCM, IPC, EBCM, etc. This happens because
    I can confirm that it is usually a minimum of 2 incorrect envrionment identifiers that can trigger a vehicle starting to be disabled next time.
I have this same code logged in the IPC of a Brazilian 2015 GM Onix 1.0 MT LT (Global A). Additionally, it appears as B3926-00 in the BCM.
Hi, "incorrect immobiliser identifier" you will get this DTC whenever you install a used module that's on the GM vehicle's secured system, for example, a used BCM, IPC, EBCM, etc. This happens because the used module's immobiliser security code differs from the vehicle you're repairing. To program the correct immobiliser identifier code for the vehicle you're repairing onto a used module, you need to use GM SPS or DPS to remove and reprogram the vehicle keys. Also, to remove and program the vehicle keys, all modules on the GM vehicle's secured system must have the same PIN and VIN stored in them.
More information is listed in this article.
The environment identifier is used to prevent the swapping modules between vehicles. The body control module (BCM) is the keeper of the environment identifier. The instrument cluster, electronic brake control module, HVAC control module, inflatable restraint sensing and diagnostic module, engine control module (ECM), and steering column lock module (if equipped) each learn the environment identifier during their configuration process. During vehicle operation, the BCM sends the immobilizer identifier as a challenge and each module responds to the challenge by sending the environment identifier back to the BCM. If the BCM sends an incorrect immobilizer identifier or a specific number of incorrect environment identifiers are received, vehicle starting is disabled.
This is interesting as HMI is not part of Immobiliser enviroment. As @Arbe_gtc said. Any J2534 interface will do and we can help you with resetting them to factory :)
I found it suprising too, but apparently every global-A module learns the identifiers, even the ones that arent integral to the imobilizer environment or use PINs.
Can you elaborate on what you mean by "any J2434 intrlerface will do?" I know what a J2534 is, i have all the major OEM ones including the MDI2. Are you saying that i can use it to reset the modules and/or edit bin files? With what software? From what ive seen, the basic vin reset, Pin reset, etc from DPS isnt guarenteed to fix it even after i spent all the money. In a normal situation, B3902 would be corrected by performing a simple Immobilizer relearn procedure, but ive done that twice with no luck. If the PIN or VIN were incorrect, then i should be setting other DTCs.
It seems like there are immobilizer identifiers stored somewhere in the bin file that SPS2 is unable to locate. It performs the procedure successfully, but fails to correct the B3902. I expect that the bytes will need to be manually located or the entire bin file will need to just be replaced with a virgin file.
Is it possible for you to run the VCAP on SPS2 and share the vcap file with us so we can review it?
Software for this kind of stuff exists ;)
Are you sure that HMI made other modules reset their Security code? Or you tried to do something on the car that erased the security code from the modules you said. (key relearn)
For example if IPC does not have the correct Security code, it will throw an error for wrong environment. BCM will throw an error too because it doesn't recognize IPC as a module from the environment.
An incorrect security code simply prevents you from reprogramming the immobilizer (including relearning the environment ID). If everything in your vehicle is paired correctly and you change the IPC PIN, it won't trigger an "incorrect environment identifier" error.
The error appears when a used and unreset unit is installed in another vehicle; even if you correct the PIN and VIN, the error persists. I drove my car for a long time with a LaCrosse speedometer and error B3926 00 (Incorrect Environmental Identifier Received From Instrument Cluster) in the BCM, and nothing ever happened—until I relearned the keys.
Had same issue with retrofitted IPC. When i changed PIN to match BCM, error disappeared. No need for Key relearn.
In all the BCMs I’ve tested, the immobilizer environment DTC never cleared—even after simply changing the PIN and VIN—until I relearned the keys and the environment ID. There is a specific DID (though I don't recall which one) that "hides" the environment immobilizer DTC.
After i installed the improperly remanufactured HMI, i did not perform an immobilizer relearn. All i performed was the applicable HMI configuration. After the installation and programming was complete, i scanned the vehicle and found B3902 was set in the IPC, EBCM, CCM, and the HMI, then spread further into the IRSDM after taking it for a test drive. These are all active DTCs and cannot be cleared.
As i said, this isnt supposed to be possible, but i have confirmed with multiple independant sources that this is a known, extremley rare issue. The issue was described the same way by everyone, including AC Delco themselves; the incorrect imobilizer identifier from the used module somehow propagates into the vehicles other modules, overwriting the other modules imobilizer identifiers. This is only known to happen on Global-A vehicles, usually the very early year models.
Nothing i did on sps2 after installing the used HMI should have had any effect on the immobilizer identifiers. Then after peforming no other procedures, the B3902 continued spreading, so far into just the IRSDM. This is exactly as other reports of this propagation issue have reported. I feel rather confident that this vehicle is experiencing the propagation glitch, not simply has configuration errors caused by failed service routines.
Honestly, no idea. Ive never heard of vcap, and when i click on the name it brings me to a 404.
Are you sure it was just the B3902 that was being reported? From what ive read, the PIN being incorrect should cause other DTCs other than B3902, which i do not have. If your right and a pin relearn can actually correct B3902, this may be something i need to look into.
Pretty sure.
B3926 and B3980 are from BCM
B3902 is from IPC
That article about the Vcap tool was hidden. I unhide it. The link to the vcap word now works.
You know if there are some TSB about that?
1 hour ago, Adelin said:
Pretty sure.
B3902 is from IPC
This is pretty interesting. Your BCM is acknowledging the incorrect identifier in the IPC, but my BCM isnt acknowledging the incorrect identifiers in a single one of my modules. Even after a test drive, the only DTCs returning are the B3902s in the 4 modules. No others.
I appologize that i have zero illustrations or files to back up what im describing, as i said, im new here. I still need to get all the dps software set up on a laptop before i can get you guys everything. I think im gonna be purchasing a seperate laptop just for all of this stuff, cause i currently use my personal laptop for alot of school stuff which is picky as hell about what programs it sees installed. Id use one of my work laptops if i didnt think the owners would mind, but theyd most definitely not be happy to find i installed a bunch of 3rd party software onto any of their devices. Ill order a laptop very soon, likley this evening.
For now, OEM documents are about all i can offer, as well as all the build data / RPO codes. Also, as thanks, feel free to DM me if there are any OEM documents youd like me to get for you, as well as build data just like i have given bellow. Usually it'll take me no more than 30 minutes, and it doesnt need to be GM.
Build data:
Model designator:
6NG26 : SRX CROSSOVER 4 DR
Build Date:
20140611
Year:
2014
Major Division:
C : Car
Division:
6 : CADILLAC
Series code:
NG
Bodystyle code:
Book:
N
Catalog Code:
6N1 : CADILLAC SRX
Primary Color Code:
8555 : Black
TRIM COLOR SEAT:
01A : TRIM COLOR SEAT JET BLACK
TRIM COLOR DOOR PANEL:
1AB : TRIM COLOR DR PANEL JET BLACK
PACKAGE/SALES PACKAGE:
1SB : PACKAGE-OPTION 02
FINANCIAL PROGRAM / FLEET PROCESSING:
1SZ : PACKAGE OPTION
INTERIOR DOOR MOLDING:
2BX : MOLDING DOOR INTR CHOCO SAPELE
STEERING WHEEL COLOR:
44F : STEERING WHEEL COLOR CHOCO SAPELE
TRIM COMBINATION * NOTE: USED FREQUENTLY AS REPLACEMENT FOR PRODUCTION FAMILY CODE "CCM" TO OPTIMIZE PART FILTERING RESULTS:
4AA : INTERIOR TRIM JET BLACK
WHEEL SPARE:
5A7 : SPARE WHEEL DELETION
KNOB / CAP:
5AD : KNOB CHOCO SAPELE
COMPONENT FRONT LEFT:
6AA : SPRING COMPTR SELECT FRT LH
COMPONENT FRONT RH:
7AA : SPRING COMPTR SELECT FRT RH
COMPONENT REAR LH:
8X2 : COMPONENT RR LH NON-COMPUTER SEL SUSP
TIRE SPARE:
9L3 : TIRE SPARE DELETE
COMPONENT REAR RH:
9X2 : COMPONENT RR RH NON-COMPUTER SEL SUSP
DRIVING/PERFORMANCE PACKAGE:
AAB : MEMORY DRIVER CONVENIENCE PACKAGE
INTERIOR TRIM CONFIGURATION:
AFC : INTERIOR TRIM CONFIG #3
ADJUSTER PASS ST:
AG2 : ADJUSTER PASS ST POWER, MULTI-DIRECTIONAL
ADJUSTER PASS ST:
AG2 : ADJUSTER,SEAT,6-WAY POWER,SPLIT BENCH,PASSENGER
VEHICLE SAFETY & COLLISION AVOIDANCE:
AL0 : SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR
SEAT CUSHION CONTROL:
AL2 : CONTROL SEAT, POWER LUMBAR
EQUIPMENT -:
ANY : EQUIPMENT CARGO RAILS AND TIE DOWNS
SEAT:
AR9 : SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE)
EQUIPMENT -:
ASV : EQUIPMENT SENSOR AIR MOISTURE & W/S TEMP
LOCK CONTROL, REMOTE ENTRY:
ATH : LOCK CONTROL, ENTRY REMOTE ENTRY, EXTENDED RANGE, PASSIVE ENTRY, ALL D OORS
VEHICLE TYPE:
AXP : VEHICLE TYPE MULTI-PURPOSE PASSENGER VEHICLE
RESTRAINT SYSTEM:
AY0 : RESTRAINT SYSTEM SEAT, INFLATABLE, DRIVER & PASS, FRT SIDE, ROOF SIDE
REMOTE START VEHICLE:
BTV : CONTROL REMOTE ENGINE START
ROOF:
C3U : ROOF SUN, GLASS, SLIDING, ELEC, TRANSPARENT GLASS FIXED
GVW RATING:
C6S : GVW RATING 2,520 KG
WIPER & WASHER- ALL:
CEC : WIPER SYSTEM WINDSHIELD, INTERMITTENT, MOISTURE SENSITIVE
HVAC SYSTEM / INTERIOR HEATER:
CJ2 : HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT
COVER, REAR COMPARTMENT / TONNEAU COVER:
D42 : COVER,REAR COMPARTMENT SECURITY(SHADE)
SALES PROCESSING:
DCP : PROCESSING DIRECTIONS & CONNECTIONS SERVICE PACKAGE
MIRROR I/S R/V:
DD8 : MIRROR,INSIDE,REARVIEW,TILT,AUTOMATIC,LIGHT SENSITIVE
MIRROR O/S:
DR4 : MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL,ELEC,HTD,LT SENS,POWER FLDG
TRIM SEAT:
EBS : TRIM SEAT LEATHER, NUANCE SANDSTONE, MINI-PERF
COUNTRY:
EF7 : COUNTRY UNITED STATES OF AMERICA (USA)
MODEL CONVERSION:
EPM : MODEL CONVERSION-ALL WHEEL DRIVE W/TRANSFER CASE
RATIO:
F07 : RATIO TRANSAXLE FINAL DRIVE 3.39
F46 : CHASSIS DRIVE LINE ALL WHEEL DRIVE (AWD)/FOUR WHEEL DRIVE(4WD)
TRIM DOOR:
FBJ : TRIM DOOR VINYL, SHEFFIELD PROTEIN
SUSPENSION SYSTEM:
FE2 : SUSPENSION SYSTEM,RIDE AND HANDLING
VEHICLE FUEL:
FHO : VEHICLE FUEL GASOLINE E10
PRIMARY COLOR:
GBA : PRIMARY COLOR EXTERIOR, BLACK (G) 8555
ENGINEERING YEAR:
I14 : ENGINEERING YEAR 2014
PEDAL:
JF4 : PEDALS ADJUSTABLE, POWER
SUSPENSION REAR:
JJK : SUSPENSION REAR INSTALLED (MODULAR OPTIMIZATION METHOD ONLY)
BRAKE SYSTEM:
JL9 : BRAKE SYSTEM,POWER,FRONT AND REAR DISC,ANTILOCK
SEAT HEATER / HEATED SEAT:
KA1 : HEATER - SEAT
TIRE INFLATOR KIT:
KTI : KIT, TIRE INFLATOR
ENGINE:
LFX : ENGINE GAS, 6 CYL, 3.6L, SIDI, DOHC, VVT, E85 MAX, ALUM GM
VEHICLE DRIVE:
LHD : VEHICLE DRIVE LEFTHAND DRIVE
TRANSMISSION:
M7U : TRANSMISSION AUTO 6 SPD, 6T70, AWD, GEN 2
MARKETING AREA:
MAH : MARKETING AREA NORTH AMERICA, PUERTO RICO/USVI
EMISSION SYSTEM:
NE1 : CERTIFICATION EMISSION, GEOGRAPHICALLY RESTRICTED REGISTRATION FOR VEHICLES UP TO 14, 000 LBS GVW (USE 2
STEERING WHEEL:
NP5 : STEERING WHEEL,LEATHER WRAPPED
EMISSION SYSTEM:
NU5 : EMISSION SYSTEM CALIFORNIA, BIN 4
PCW : CONTROL SALES ITEM NO. 114
TIRE ALL:
QMY : TIRE ALL P235/65R18-104H BW TL AL3
R9N : CONTROL - SALES ITEM NO. 89
RADIO:
RAO : RADIO BASE
WHEEL:
RV1 : WHEEL 18 X 8.0, J, ALUMINUM, DESIGN 3
PLANT CODE:
SAL : PLANT CODE- RAMOS ARIZPE, MEXICO GM DE MEXICO
SALES PROCESSING:
SLM : SALES PROCESSING-STOCK ORDERS
LAMP SYSTEM:
T61 : LIGHTING,DAYTIME RUNNING
BODY EQUIPMENT:
TB5 : BODY EQUIPMENT LIFT GATE (POWER)
HEADLAMP HIGH BEAM:
TQ5 : CONTROL INTELLIGENT HIGH BEAM
LAMP:
TSQ : LAMP PACKAGE INTERIOR, DELUXE
DIGITAL AUDIO SYSTEM:
U2M : DIGITAL AUDIO SYSTEM S-BAND AND HD
THEFT DETERENT SYSTEM:
UA6 : THEFT DETERRENT SYSTEM
PARK ASSIST:
UD5 : PARK ASSIST FRONT AND REAR
DISPLAY INSTRUMENT:
UDD : DISPLAY INSTRUMENT DRIVER INFO ENHANCED (MULTI COLOR GRAPHIC)
UE1 : COMMUNICATION SYSTEM VEHICLE, G.P.S. 1
SENSOR INDICATOR:
UEC : SENSOR INDICATOR AUTOMATIC AIR RECIRCULATION
SENSOR INDICATOR:
UEU : SENSOR INDICATOR FORWARD COLLISION ALERT
SENSOR INDICATOR:
UFG : SENSOR INDICATOR REAR CROSS TRAFFIC ALERT
LANE KEEP ASSIST WARNING:
UFL : SENSOR INDICATOR LANE DEPARTURE WARNING
SIDE ACTIVE SAFETY:
UFT : SIDE ACTIVE SAFETY OBSTACLE DETECTION
OPENER:
UG1 : OPENER GARAGE DOOR, UNIVERSAL
SPEAKER SYSTEM:
UQS : SPEAKER SYSTEM PREMIUM AUDIO, BRANDED SURROUND AMPLIFIER
VISION:
UVC : CAMERA REAR VIEW
NAVIGATION DISC DATA:
UY4 : DISPLAY NAVIGATION SYSTEM
CROSS BAR OR RAIL:
V64 : RAIL ROOF, SILVER
VEHICLE STATEMENT:
V8D : VEHICLE STATEMENT VEHICLE LABEL CONTENT - U.S. FMVSS
OWNERS MANUAL:
VH9 : ENVELOPE,OWNER INFORMATION MANUAL
OWNERS MANUAL:
VT7 : OWNERS MANUAL ENGLISH LANGUAGE
PANEL CENTER:
VVO : PANEL CENTER CHOCO SAPELE
VIN MODEL YEAR / FORMAT:
VZE : VIN MODEL YEAR 2014
Submodel:
392 : Luxury
Wheel Base (Inches):
WBI#110.5 : 110.5
Wheel Base (Metric):
WBM#280.7 : 280.7
Region:
1 : USA United States
Engine Designation:
4495 : LFX
Engine VIN:
6 : 3
Valves:
5 : 24
CC:
ECC#3564 : 3564
CID:
ECD#217 : 217
Liter:
ENL#3.6 : 3.6
Engine Bore (Inches):
EBR#3.70 : 3.70
Engine Bore (Metric):
EBM#94.0 : 94.0
Engine Stroke (Inches):
EST#3.37 : 3.37
Engine Stroke (Metric):
ESM#85.6 : 85.6
Cylinders:
CYL#6 : 6
Fuel Delivery Sub Type:
23 : DI
Fuel Delivery Type:
5 : FI
Fuel System Control Type:
5
Fuel System Design:
6 : SFI
Aspiration:
5 : Naturally Aspirated
Cylinder Head Type:
6 : DOHC
Fuel Type:
7 : FLEX
Ignition System Type:
6 : Distributorless
Engine Manufacturer:
11 : General Motors
Engine Version:
3 : N/R
Power Output (Horse Power):
PHP#308 : 308
Power Output (Kilowatt Power):
PKW#230 : 230
Body Number of Doors:
5 : 4
Body Type:
11 : Sport Utility
Bed Length (Inches):
N/R
Bed Length (Metric):
N/R
Bed Type:
3 : N/R
Brake Type (Front):
5 : Disc
Brake Type (Rear):
5 : Disc
Brake System:
5 : Power
Brake ABS:
8 : 4-Wheel ABS
Spring Type (Front):
5 : Coil
Spring Type (Rear):
5 : Coil
Steering Type:
6 : Rack
Steering System:
5 : Power
Transmission Manufacturer Code:
2080 : 6T70
Elec Controlled:
2 : Y
Transmission Num Speeds:
9 : 6
Transmission Control Type:
5 : Automatic
Transmission Type:
6 : Transaxle
Publication Stage:
4
Engine Block Type:
BLT#V : V
Transmission Manufacturer:
11 : General Motors
Pretty sure.
B3902 is from IPC
B3902 - Incorrect Immobilizer Identifier Received.PDF Diagnostic Information and Procedures - DTC B3902.PDF
I actually asked Acdelco this exact question when i had them on the phone. They said that there hasnt been enough verified reports of the identifier propagation for a tsb to be officially created. There are only tsbs for general warnings of installing used modules, expessing that the modules may become damaged; none that go into detail of identifier propagation. Here is the bulletin im referancing.
PIP4670J.pdf
I just ordered a secondary laptop that i can install all of this stuff on. I cant risk installing 3rd party software on my otherwise all OEM software toughbook. The company i use to supply all of my OEM J2534 tools, Software, and licensing, has gotten pissy with me in the past for doing this with ForScan. The new laptop should be delivered September 29-30th. This laptop will double as my new ForScan machine, so thats exciting Also. I will try my best to get these files posted as soon as i can, thanks.
  • +Unhappy_Node changed the title to Incorrect Immobilizer Identifier Propagating to All Nodes In-Network With the Gateway
  4. Arbe_gtc
  5. hassan77h
jjagel uglyoldbastard Cleberson Santos Unhappy_Node Mikluha_Maklay OpelGuy Adelin Arbe_gtc Opelinsignia1985 YaserGM zph666 paul mike blocked Enterlan tobiasp pupu14 TunnerXP alatka asd Robi_X hassan77h
