Activating window opening/closing via the key fob on a Chevrolet Cruze
Hello everyone. I came up with the idea of enabling remote window opening on the first-generation Chevrolet Cruze. Has anyone managed to do this? I compared the calibration files for the Cruze and the Mokka (specifically file no. 11) and made some changes. All the windows open using the remote, but only the front ones close.
  • Replies 11
  • Views 631
  • Try BCM files for the Vauxhall Insignia. BCM_Insignia_W0LGT8ET4E1199075.zip
  • BLKATSG
    BLKATSG
    39109237 is the stock Cruze calibration, and the modified one. 39104006 is the same year Opal that has the remote windows up and down. 11-39109237.bin 11-39109237 remote windows.bin 11-39104006.bin
  • BLKATSG
    BLKATSG
Hi. Thanks—I’ll give it a try and let you know. It seems to me, though, that this isn't possible via software on the Cruze—based on the RPO codes:
AEF: Power window, passenger, express up/down
AEQ: Power window, rear doors, express down
...so I’d likely need to replace the rear window modules with automatic ones. Still, I’m going to give it a shot.
I got remote window down and up to kind of work on the 2nd gen Cruze.
I currently have 3 windows that go down with the remote and the option to turn it on and off in the radio menues.
I was struggling to find the drivers window byte so It only lowers the 3 windows.
Hi. Could you provide the RPO codes for the windows? And could you send me your files for comparison?
AED - WINDOW POWER OPERATED, PASSENGER, EXPRESS DOWN
AEQ - WINDOW POWER OPERATED, RR DRS, EXPRESS DOWN
There is options in the calibrations to open or close all the way or only when you hold the button on the remote.
Your BCM cals are going to be different from my 2nd Gen Cruze files
If possible, please send calibration file No. 11—both the version from before the changes and the one from after. I will examine the differences between the 1st and 2nd generation Cruze models.
Which window isn't working? Does it not respond at all, or does it fail to open or close using the remote control?
I thought I responded to this. I guess not.
The drivers (Front Left Hand) window does not go down with the remote, but it works find with the switch.
@BLKATSG Do you happen to have WhatsApp or Telegram? It would be easier for us to communicate. If so, please send me a private message—I don't have the permissions to initiate one myself.
  2. GM-Enthusiast
  4. Last_Captain
    +Last_Captain
    17
  5. pupu14
    +pupu14
    11
IBRA Daniil_Ast John Stevens dogwulf ABOMAZEN TunnerXP tan tan Cleberson Santos crakavelli Pavel Galaxie alatka asd Mindaugas Cernius JBL_1989 thxx Savip_ Adelin Jasper BLKATSG blocked
