USED REMOTE KEY
HELO EVERYONE I WAS WONDRING IF WE CAN LEAR USED KEY FOB FOR EXAMPLE I HAVE C7 USED KEY FOB I WANT TO PROGRAM FOR A DIFFRENT VEHICLE IS POSIBLE
OR NO
THANKS .....
  • Views 261
  • Arbe_gtc
    Arbe_gtc
    A used key isnt possible relearned in other car. Need reset the to Virgin status for that A learned key can be reused in the same car if change only bcm or ecm, if you change both at same time, need
  • Inam Ullah
    Inam Ullah
    THANKS BRO Arbe_gtc
  • pupu14
    pupu14
    You can't pair just about any key to any GM vehicle.. If Corvette key have same transponder chip, encryption key, frequency etc with a vehicle you want to pair with - then should be doable. To che
  • Arbe_gtc
    Arbe_gtc
To check compatibility, you can run Transponder key diagnostics in immo learn procedure, or use aftermarket keyfob readers.
THANKS PUPU14 FOR REPLY SO NICE OF YOU
A learned key can be reused in the same car if change only bcm or ecm, if you change both at same time, need new Keys.
I have in bench 7 bcms different working with the same keys
Resume, if buy a used key you cant programm It.
THANKS BRO Arbe_gtc
regloops Garik67 remiga muraskinas exc11 aleks nik Shifty Robi_X BLKATSG Mikluha_Maklay Arbe_gtc hassan77h Last_Captain High Galaxie Opelinsignia1985 JBL_1989 Mindaugas Cernius E-Ing-X20XEV GMcars tobiasp
