Has anyone successfully retrofitted Remote Start on a GM vehicle? What modules / programming were required?
2 minutes ago, Adelin said:
Can’t remember but saw some info somewhere regarding that you have to do some wire adding/modification on hood locking mechanism. Basically BCM needs to see that the hood is closed in order to remote start on your car
If you don't have the hood ajar switch you will need to ground the pu wire coming out of X2 on the BCM. I already did that....
  • Replies 26
  • Views 888
    and have correct ECU files to flash
  • Arbe_gtc
    Arbe_gtc
    In several Cars only editing the bcm calibrations the remote start works
  • Teklock
    Teklock
stensin Gekko Daniil_Ast Adelin Vericu MaxGood aleks nik syciu regloops Garik67 tahoecoding Mohammed Aljack PAMM Enterlan Shifty bajad Robi_X TunnerXP blocked hassan77h
