Has anyone successfully retrofitted Remote Start on a GM vehicle? What modules / programming were required?
Hi everyone,
I’m curious if anyone here has successfully retrofitted or enabled the OEM Remote Start function on a GM/Opel vehicle that originally didn’t come with it from factory.
I’d like to know:
  • Which vehicle/platform did you do it on?
  • What hardware was required (BCM, key fobs, etc.)?
  • Any immobilizer / security challenges?
  • What was the procedure for doing this? (step by step)
Thanks in advance for sharing your setups and lessons learned.
  • Replies 26
  • Views 886
    and have correct ECU files to flash
  • Arbe_gtc
    Arbe_gtc
    In several Cars only editing the bcm calibrations the remote start works
  • Teklock
    Teklock
    If you don't have the hood ajar switch you will need to ground the pu wire coming out of X2 on the BCM. I already did that....
Do we have any volunteers who would like to work on this topic and achieve BTV, or anyone who already did this, can you throw us any clue.
Whoever is ready to work with me, feel free.\
If needed, i can source cars for testing.
I have it done on Vauxhall Insignia B, 2l diesel. Involve programming on ECU/BCM. Can be done with original key, but I decide to source Buick key as have dedicated button and look better.
I have sourced a Suburbans stock and Remote start cals for both ECU and BCM, but ECU cals 5,6 and BCM 2,5 which were different, were way more different on structure and size compared to Opels one.
Is there any other clue that you could share in private or here for all. At least if same cals are involved and how many bytes needs to be change.
Cheers
Cheers
editing ECM calls is very sensitive area, not many people can edit them, reason behind this as they need to be unpacked, edited, checksum calculated and them packed again.
Are you talking about the whole ECM flash? Or just the calibrations? Checksum can be made in the same way you do the HMI ones
checksum can be made, but unpacking, editing and packing it back as they should be been told is bit tough process
24 minutes ago, Camelot said:
if we could identify only BTV bytes on both ECU and BCM, rest should not be an issue
there is your mistake, BCM is easy to deal...ECU is completely different story
And thats how we learn, from mistakes, right? :D
yep, that is way, but there is conciquences as might kill module
10 minutes ago, Camelot said:
Not for E98. easy to recover on boot 🤣
anyway thanks for your hints Lyubomir
on E98 even no need editing calibrations, there is already ready to use
so for example if i have a 2019 Astra K D16DTH with AdBlue, i just need to edit BCM calibrations for it to work?
Did you find this feature in your K? ;)
my k its manual, not possible
after modifying BCM 2 and 5 on 3 cars with E98 Ecu, Remote Start option was present but car doesnt remote start.
Either this feature requires 4/5 Button Key, or ECU modifications. i will order a 5 button key and retry.
it need ECM modifications as well
I can't test it just yet because I have an unrelated issue with my car and have the check engine light on, but according to the data coming out of my BCM it is indeed getting the request to start when I push the correct button on my remote.
Can’t remember but saw some info somewhere regarding that you have to do some wire adding/modification on hood locking mechanism. Basically BCM needs to see that the hood is closed in order to remote start on your car
stensin Gekko Daniil_Ast Adelin Vericu MaxGood aleks nik syciu regloops Garik67 tahoecoding Mohammed Aljack PAMM Enterlan Shifty bajad Robi_X TunnerXP blocked hassan77h
