astra k clocks into astra j tps and front camera errors
hi i have put astra k ipc into a astra j and cars working .but i am getting warning for front camera and tps warnings and the ipc plus imo Environment error . my car dose not tps and a front camera. how do i edit these out and what sofware do i need i got dps do i need xml editor. the clocks are astra k 39060519 thanks
Solved by Arbe_gtc
  • Views 366
  • Of course, need to adjust new cluster to your car specs.. Camera error - through XML configuration. TPMS warning - will have to modify a binary calibration file and program with DPS. For environment e
  • Control unit's (IPC) immo data is not synchronized with the rest of the vehicle - need to perform Immo Learn (with DPS or via SPS). You can have up to 3 control modules with this error - if there is m
For environment error - need to do an immo procedure. You will have to change PIN and VIN inside your donor cluster beforehand, if it was not done at all...
This is not year 1995 anymore, where every part could just be swapped around as plug-N-play...
All ready done a vin and pin program using DPS files but still immo environment error threw gds2 on the cluster side when u check for errors but car runs with the error and what XML editor do I need and is the a binary a DPS file needed of hear or can just download of the net for free
Control unit's (IPC) immo data is not synchronized with the rest of the vehicle - need to perform Immo Learn (with DPS or via SPS). You can have up to 3 control modules with this error - if there is more, immo will prevent vehicle from starting as anti-theft measurement.
Use DPS built-in functionality to adjust RPO codes - use ECU Configuration and Create Build Data.
And post full scan log from GDS2 - this will make things so much easier for everyone!
do i have to get this file IMMO Immobiliser learn, Insignia Buick regal and others - Type4 DPS Files - www.CameraLoops.ru already have type 4 option how can i download it without the monthly subscription fee thanks or can i do it with opcom to re program keys in
E-Ing-X20XEV apetrushenko ABOMAZEN WSOpel Marcin Tulowiecki Ramin MoeMan exc11 Jasper marcel_hack_guy bondarrenko Opelfan Encrypted Owner Galaxie nev3r tobiasp hassan77h sakeer blocked Opelinsignia1985
